Home > Maintenance & Mods (L322) > Oil in the spark plug well |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 900 |
Just replace your cam cover seals pretty standard issue on these engines and you should be good. |
3rd Jan 2021 3:01pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
That an easy job to do is it? |
3rd Jan 2021 3:03pm |
3rd Jan 2021 4:13pm |
Cheers dave.
3rd Jan 2021 4:39pm |
Yeah order some up island 4x4 are good you need left and right side the kits usually come with outer and inner gaskets.
3rd Jan 2021 6:52pm |
Already done mate. Ordered it all from island 4x4 as I need the alternator O ring as well. Looked it up and it seems easy enough to change.
3rd Jan 2021 7:54pm |
ChrisRRV Member Since: 30 Jun 2020 Location: Belfast Posts: 104 |
Have the exact same thing myself
5th Jan 2021 2:41pm |
Don't forget the bolt/nut rubber seals as well mate. I made the mistake order the gaskets but forgot the bolt and nut rubber seals so held me up a day |
5th Jan 2021 2:44pm |
These?
5th Jan 2021 2:58pm |
Think that's the ones mate. I ordered mine from land rover as seals, gaskets I always go genuine. These two in the circle mate
5th Jan 2021 3:06pm |
cheers |
5th Jan 2021 4:10pm |
vs322 Member Since: 08 Apr 2020 Location: Athens Posts: 584 |
May I suggest you had bead blasted and powder coated the covers while you are at it? It's well worth it. And since you changed the spark plugs, funds permitting, I'd also change the ignition coils... |
5th Jan 2021 4:57pm |
Vs322
5th Jan 2021 5:20pm |
Mainly cosmetic reasons. One could also argue that the gasket channels would provide better sealing if treated. I had mine done for a modest sum, can't remember exactly so I'm confident it won't break the bank. Just make sure not to powder coat the inside. |
5th Jan 2021 5:45pm |
