![]() | Home > Maintenance & Mods (L322) > Viscous Fan to Electric Fan / Cool running 4.2 SC in testing |
andyt109 Member Since: 23 Nov 2020 Location: London Posts: 29 ![]() ![]() |
Hi All - 2006 4.2 SC
Strider Member Since: 08 Jun 2015 Location: Hertfordshire Posts: 507 ![]() ![]() ![]() |
Hi Andy,
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1371 ![]() ![]() |
Your temps are running a bit cold. Should be around 95 normal running afaiu? |
maric995 Member Since: 04 Apr 2019 Location: zagreb Posts: 58 ![]() ![]() ![]() |
Normal coolant temperature should get to 88-91 in winter driving, you should check thermostat, it is fairly easy to replace, you can check for video ''atlantic british coolant thermostat replacement'' on youtube.
Thanks all for your responses.
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2231 ![]() ![]() ![]() |
May I ask what the point of this conversion is? Current stable:
Viscous fans are unreliable, limited air flow at idle, bulky large cowl which obstructs front of engine access, sap power (although negligible), make an awfully loud fan noise at engine speed which detracts from the v8 sound (sounds so much better when it's disengaged/not fitted), |
No not at all I was genuinely curious... isn’t there a legacy plug iirc for an electric fan left from the BMW era is this connected?
That sounds interesting, I'm not sure! Would be good if there is. If you have any suggestions as to locations / circuit diagrams etc that would be appreciated.
The fan on the 4.2 sc is not just a viscous fan its also controlled by various inputs electrically, I'd leave well alone tbh |
I did think of that, but also run it for 5 days without it at all and no alarms whatsoever. All inputs arent heavy enough gauge fan current, so must be control only. I would imagine: ground, clutch control low speed, clutch control high speed, and possibly some sort of PWM return to to Ecu to check its speed. Although it's not flagged any faults up so far, so not sure what else they could be. Perhaps someone can shed some light on that. |
I wouldn't remove the viscous fan, aircon has an input as does gearbox temp.
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
cool running engine would suggest an issue with thermostat either the seal or the wax in it has broken down.
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
A properly functioning viscous fan performs very well with very few down sides. Note it was designed to work in Iceland in -30 winter to the Arabic deserts in the height of summer in 55+ degrees working hard in the sand dunes at low speeds/high loads with the air on cranked up on fully cold, getting any performance benefit over the OEM system is near impossible.
