Home > Maintenance & Mods (L322) > In-car Tool Kit?
lschwarcz
United States 2009 Range Rover Autobiography 4.2 SC V8 Bournville
In-car Tool Kit?
Hi Everyone,
I'd like to make an emergency tool kit to keep in my L322. What I call an RSR Kit for my "Road-Side-Repair Kit."
Here's the list I have so far. Anything I should add?
  • Jumper cables
  • Needle nose pliers
  • Slip joint pliers
  • Vise Grips
  • Electrical tape
  • Ratchet
  • Breaker bar
  • Socket extension
  • Sparkplug socket
  • Sockets: 10mm through 17mm
  • Gloves
  • Rags
  • Tarp to lay down on ground
  • Utility knife
  • Adjustable wrench
  • Hammer
  • Flat blade and Philips screwdrivers
  • OBDII reader (Gap-Diagnostics IID)
  • Grime Boss or other type of hand cleaner
  • Flashlight
  • Reflective roadside triangles
  • Ice/Snow scraper
  • First aid kit
  • Tire pressure gauge
Thanks!
Larry. 2009 Range Rover L322 Autobiography
Bournville/Ivory
Save lives, give blood.
Post #578291 3rd Jan 2021 7:16pm
CongoBoy
South Africa 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
There will be other replies for additions but a frw things I always put in are:
- a roll of the silicon seal-sealing tape. This is brilliant for split hoses
-a decent tow strap/rope with shackles.
- a jumper battery pack. I now use the smaller ones, available off the Net.
- a proper jack!!
Just my two-cents worth but these have helped me out no-end!!
Cheers,
Matt
Post #578296 3rd Jan 2021 7:43pm
you dont need all that ,just a subscription to a breakdown service... Thumbs Up ... - .- -.
Post #578302 3rd Jan 2021 8:16pm
1 - 800 FFS HELP
Whistle Very Happy Thumbs Up
Post #578352 4th Jan 2021 12:56am
lschwarcz
OK. Who does that call?
Thanks,
Bournville/Ivory
Post #578354 4th Jan 2021 12:59am
4434Morrison
United Kingdom 2012 Range Rover Vogue SE TDV8 Santorini Black
Hi Larry,
The US number you need to call is 1-800-AAA-HELP.
Best get the highest level membership in the AAA.
Avoids the necessity to carry an extensive range of tools and spares in your FFR Smile 2012 4.4 TDV8 Vogue SE Current
2015 E220 with AMG Sport Pack - Currently driven by my son
2010 3.6 TDV8 Vogue - Written off by my son
Post #578362 4th Jan 2021 7:50am
10mm combination spanner (open end and ring)
Most things are held on with a 10 mm nut believe it or not, and many of them you cannot get at them with a socket set. .
Post #578381 4th Jan 2021 11:19am
It is a well known fact that all you need is
WD-40
Duct tape
hammer
If it doesn't move and it should, use the WD-40. If it moves and it shouldn't, use the duct tape. If either doesn't work, use the hammer
Rolling with laughter Pete
Post #578386 4th Jan 2021 11:46am
lschwarcz
Haylands,
What I always heard is all you need is a hammer and a condom. If something breaks, hit it with the hammer. If that doesn't fix it, f*@k it. Rolling with laughter
Sorry, I couldn't resist!
In truth, the ONLY thing you need is a cell phone and a credit card. But I'm hoping to be a little more prepared than that.
Bournville/Ivory
Post #578427 4th Jan 2021 4:55pm
If you're packing all that, it's probably worth adding a 22mm socket for removing the wheels
Post #578446 4th Jan 2021 7:55pm
...and a 23mm socket for when the nuts are swollen.. ... - .- -.
Post #578454 4th Jan 2021 8:34pm
Range Rover L322
IIDTool
and maybe heatshrink self solder butt splice electrical connectors (and heat gun or lighter). Particularly useful if you get the Adaptive Dynamics fault.
Post #578479 4th Jan 2021 11:33pm
lschwarcz
I believe the Adaptive Dynamics fault is only an issue on MY '10+. Not on my '09.
Thanks!
Bournville/Ivory
Post #578483 5th Jan 2021 2:00am
D3Jon
Cheers,
Matt
I'd second that, everyone should carry a roll of that stuff. Brilliant and has got me out of a fix when a coolant hose has gone bang.
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #578491 5th Jan 2021 8:15am
D3Jon
Brilliant and very true! 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #578492 5th Jan 2021 8:16am
