Home > Maintenance & Mods (L405) > Front Brake pads & Dynamic Bushes |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 768 |
Okay, so there are some very ambiguous terms being used by your dealer. There are no such things as 'Dynamic Bushes'. Likewise, there are no such things as 'ARC Bushes'.
3rd Jan 2021 8:32pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8504 |
1/2 worn pads need replacing? For £700?? Tell them to off.... yes the genuine pads are expensive, but not £700 expensive and even allowing for 2 hours of labour, and on a ramp they only take 1/2 hour to do, that’s ridiculous. Absolutely no need at 45% remaining, however having covered 36k if you haven’t had them changed it may be that the actual wear is higher. 36k is a good run for a set of pads..
3rd Jan 2021 8:42pm |
Completely agree with you NMJ, I too would be telling them to off!
3rd Jan 2021 8:49pm |
Yes, that’s sounds about right, aparently the ones on mine were done by the supplying dealer prior to me getting it at 37k. Was pointed out to me in the little condition video that my local stealer did for me while it was in to have the updated oil sensor wiring. There is nothing that can't be fixed with a hammer😜😜
3rd Jan 2021 9:02pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Sounds like you need a decent indy to me sir |
4th Jan 2021 12:53am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
I am sorry i would never go back to a place that
4th Jan 2021 9:52am |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 377 |
I was just thinking the same thing, Craig. I'd guess you could save a good part of £500 by finding a good indie... Current: - 2017 L405 3.0 V6 Autobiography Sold: - 2013 L405 4.4 TDV8 Vogue - 2004 L322 4.4 Vogue (BRC LPG) - 2002 L322 4.4 HSE (having fixed timing chain guides) - 2000 P38 4.6 Vogue (BRC LPG) - 1981 2-door In-Vogue - 1980 Ex-Army SIII LWB - 1976 SIII LWB - 1968 SIIA Stripped for parts: - 2003 L322 4.4 Vogue |
4th Jan 2021 11:18am |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8190 |
Take it to https://www.cam-tech-landrover.co.uk/ You can't be too far from him.
4th Jan 2021 11:23am |
DarrenJH Member Since: 14 Jul 2020 Location: Somerset Posts: 2 |
Thanks for all your replies, I have spoken with them this morning and they have confirmed the bushes that they replaced 2000 miles ago are the same item that now have play in them, not covered under warranty as more then 12 months ago and its just out of manufactures warranty, and the extended warranty doesn't cover these. They also said they have made a mistake with the price of the brake pads, they should be £750!!
4th Jan 2021 11:47am |
IGP Member Since: 09 Jul 2020 Location: Malvern Posts: 285 |
The bushes fitted and supplied 2000 miles ago should have a reasonable life expectancy regardless of the manufacturers warranty period. 2000 miles is not a reasonable life expectancy and I would be arguing the point with the dealer. As for the brakes, as said by others, find a decent indie. The price quoted is an absolute rip off.
4th Jan 2021 1:41pm |
Jase71 Member Since: 13 Apr 2016 Location: Portsmouth Posts: 479 |
Funny thing is that I've had my car from new and after 72,000 miles I still have plenty of meat left on my front brake pads. Weirdly I had to have the rear changed at 60k + miles!
4th Jan 2021 3:54pm |
I would steer well clear.
4th Jan 2021 6:54pm |
