Home > Technical (L322) > L322 td6 steering angle implausible fault |
mercs600 Member Since: 19 Mar 2011 Location: North Yorkshire Posts: 425 |
Check the ABS sensors. I had a similar issue and evey time I checked it said steering angle fault on the ID tool. I purchased a second hand steering angle sensor but was unable to fit it myself due to access issues. The last time I checked and cleared the fault it said rear offside ABS sensor open circuit ! Purchased a generic one and after fitting have had no further issues Did take nearly 4 hours from start to finish to remove the old one - after 18 years it didn't want to come out with a fight |
29th Dec 2020 11:10pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
You need to correct the position of the steering wheel to the straight ahead position when driving in a straight line.
30th Dec 2020 8:27am |
Wk52RR Member Since: 29 Dec 2020 Location: Devon Posts: 54 |
Do steering angle sensors tend to fail indefinitely |
30th Dec 2020 9:45pm |
Ian G Member Since: 07 Sep 2020 Location: Liverpool Posts: 35 |
DSC needs steering angle, speed and lateral G via the yaw sensor to agree. With 20 degrees of steering input and no sideways moment the system logs the fault code and implicates the steering angle sensor as it assumes your tracking is correct and you wouldn't knowingly drive around with such an obvious issue. Easily fixed - track it - fairly simple when you see what the DSC needs to operate. Its not complex enough to calibrate itself to whatever off centre position the steering wheel ends up in after being put back together without alignment. |
31st Dec 2020 2:42am |
Everything has the capacity to fail but with such an obvious issue with the steering wheel I wouldn't even be considering sensor failure until that is sorted. |
31st Dec 2020 2:43am |
Great. Just the answer I wanted. Thanks |
31st Dec 2020 9:46am |
