![]() | Home > Maintenance & Mods (L322) > 4.4 tdv8 high pressure pump noise |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
I have run it with the longer drive belt off and made little to no difference.
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
The tapping only appears after engine has warmed up also, can be heard loudly through the front grill. Use a mechanic scope the sound definitely originates from the HPFP, sounds like a bag of nails through that. The noise is not engine speed reliant.
By design they are obviously quite noisy hence the soundproofing. The tdv8 is a particularly quiet engine compared to most Diesels.
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 147 ![]() ![]() ![]() |
The rubber damper on the crancshaft pully failed on my car.With car idle use a strong torch to check the pully for wobble.There was no vibration of engine. 2012 TDV8 Vogue SE 4.4 |
Ticking noise gone.
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1300 ![]() ![]() ![]() |
What magic brew did you use? |
Carlube Diesel Fuel Injector Cleaner
alfredlervaag Member Since: 18 Jun 2020 Location: krikane 5 6037 eidsnes Posts: 7 ![]() ![]() ![]() |
https://video.fosl4-1.fna.fbcdn.net/v/t42....F&dl=1
Astanavits Member Since: 23 Sep 2024 Location: Paris Posts: 15 ![]() ![]() |
I have the same noise do you find the issue ?
aderob Member Since: 23 Feb 2025 Location: Paris Posts: 3 ![]() ![]() |
Hello Astanavits
