Home > Maintenance & Mods (L322) > 4.4 tdv8 high pressure pump noise |
JNC Member Since: 23 Feb 2020 Location: UK Posts: 292 |
I have run it with the longer drive belt off and made little to no difference.
19th Nov 2020 9:26pm |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 216 |
The tapping only appears after engine has warmed up also, can be heard loudly through the front grill. Use a mechanic scope the sound definitely originates from the HPFP, sounds like a bag of nails through that. The noise is not engine speed reliant.
19th Nov 2020 9:56pm |
By design they are obviously quite noisy hence the soundproofing. The tdv8 is a particularly quiet engine compared to most Diesels.
19th Nov 2020 10:00pm |
Frans@Yamorna Member Since: 15 Apr 2017 Location: Tzaneen Posts: 145 |
The rubber damper on the crancshaft pully failed on my car.With car idle use a strong torch to check the pully for wobble.There was no vibration of engine. 2012 TDV8 Vogue SE 4.4 |
21st Nov 2020 7:44pm |
Ticking noise gone.
26th Dec 2020 2:31pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1205 |
What magic brew did you use? |
26th Dec 2020 6:27pm |
Carlube Diesel Fuel Injector Cleaner
26th Dec 2020 7:30pm |
alfredlervaag Member Since: 18 Jun 2020 Location: krikane 5 6037 eidsnes Posts: 7 |
https://video.fosl4-1.fna.fbcdn.net/v/t42....F&dl=1
9th Jul 2021 9:02pm |
