Home > Technical (L322) > ECU Updates |
GraemeS Member Since: 06 Mar 2015 Location: Wagga area Posts: 2485 |
All modules except the PCM can be updated using the tool. Gap charge a fee for each module update, the list erroneously shows a couple of modules as not being up to date and the general advice seems to be to not update a module unless there is a good reason to do so. Excepting for the cost I would have updated all back-level modules but only updated ones where I hoped for an improvement in operation. |
22nd Dec 2020 10:29am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 738 |
I'm a dinosaur and take the view that if it isn't broke then don't fix it.
22nd Dec 2020 1:26pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1214 |
cass, I agree with you. But why do they make updates available? Must be to cure a hiccup or two somehow. |
22nd Dec 2020 1:38pm |
My guess is (and this is only a guess) that an update MAY fix some issue on some models under certain circumstances or in certain countries.
22nd Dec 2020 2:02pm |
Rodjules Member Since: 03 Mar 2016 Location: Bishops Stortford Posts: 68 |
Thank you all for your replies and advice. You have pretty much confirmed my view of 'if its not broke don't mess with it' !
22nd Dec 2020 2:17pm |
