Home > Technical (L322) > ECU Updates
Rodjules
United Kingdom 2015 Range Rover Vogue SE SDV8 Causeway Grey
ECU Updates
Morning All,
Recently purchased a GAP IID from another member and have been playing with it a bit to learn all the functions etc.
My question for the more tech minded of you than me, When in the ECU menu it tells me a number of updates are available
is this something I can do myself with the tool or is it main dealer only and are there any benefits to these or should I just
leave well alone ?
Many thanks in advance
Rod 2015 L405 Range Rover 4.4Sdv8 Vogue SE, Baltic Blue, Ivory
2012 L322 Range Rover 4.4 Westminster Baltic Blue, Ivory - Deceased
2012 Discovery 4 HSE 3.0 Sdv6 Oslo Grey, Black - Gone
2006 L322 Range Rover Td6 Vogue SE Buckingham Blue, Parchment - Gone
1996 P38 Range Rover 4.6 HSE Rioja Red, Black - Gone
1990 Landrover 110 2.5TD CSW - Why Oh Why ???
Post #576922 22nd Dec 2020 8:44am
GraemeS
All modules except the PCM can be updated using the tool. Gap charge a fee for each module update, the list erroneously shows a couple of modules as not being up to date and the general advice seems to be to not update a module unless there is a good reason to do so. Excepting for the cost I would have updated all back-level modules but only updated ones where I hoped for an improvement in operation.
Post #576942 22nd Dec 2020 10:29am
cass
I'm a dinosaur and take the view that if it isn't broke then don't fix it.
If you have a specific problem then go for it but I certainly wouldn't do it just because you can, I suspect that if you did every update available and assuming it worked without screwing something up, you wouldn't notice any difference to your car.
I would like to be wrong on this but I doubt that we are missing out on anything not having all of the latest updates.
Post #576969 22nd Dec 2020 1:26pm
kevinp
cass, I agree with you. But why do they make updates available? Must be to cure a hiccup or two somehow.
Post #576970 22nd Dec 2020 1:38pm
cass
My guess is (and this is only a guess) that an update MAY fix some issue on some models under certain circumstances or in certain countries.
Someone more cynical than me, if that's possible might suggest that they are just an excuse for dealers to charge some huge amount of money to "cure" problems that should never have been there in the first place.
Post #576976 22nd Dec 2020 2:02pm
Rodjules
Thank you all for your replies and advice. You have pretty much confirmed my view of 'if its not broke don't mess with it' !
No I have no issues with the car at all so would only be doing it because there is an update available. Think I'll just leave
well alone and save the money.
Thanks again 2015 L405 Range Rover 4.4Sdv8 Vogue SE, Baltic Blue, Ivory
Post #576979 22nd Dec 2020 2:17pm
