Home > Maintenance & Mods (L322) > Power steering fluid change |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4306 |
I plan to do this the old fashioned way of syringing out and topping up. Repeat.
22nd Dec 2020 8:22am |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 809 |
Local Indy in East Sussex |
22nd Dec 2020 3:04pm |
Bolert Member Since: 29 Jun 2021 Location: Hythe, Kent Posts: 30 |
Did the old-fashioned way work for you? Need to mine, doubt it been done. Assume procedure is just - - Syring out - Top Up - Repeat until clean. Believes its 1.6litres? Do you need the engine running and turning steering after each top-up? Thanks |
3rd Aug 2021 12:12pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Deleted |
3rd Aug 2021 1:03pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
Not sure if you can do this on the L322 but may be worth a read. Carried this out on my Freelander 2 so instructions come from the freel2 forum :
3rd Aug 2021 1:16pm |
Deleted |
3rd Aug 2021 1:22pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Nothing wrong with doing it the old fashioned way. Did it myself with a small hand suction pump and took six goes to get the liquid bright green. After each top up switch the engine on and turn steering lock to lock and repeat. If you don't have a suction pump a bike pump will work. |
3rd Aug 2021 3:31pm |
Thanks all for the tips and advice. Really good info Seems reasonably simple to do.
3rd Aug 2021 3:53pm |
Good to know, did you have engine off and jacked while doing this and turning steering each time to move fluid?? Thanks |
3rd Aug 2021 3:54pm |
Deleted |
3rd Aug 2021 4:35pm |
Just had the car on the ground and when doing the steering bit just drove the car back and forth. |
3rd Aug 2021 4:55pm |
Deleted |
3rd Aug 2021 6:42pm |
Caesium Member Since: 21 Sep 2021 Location: Essex Posts: 451 |
Going to do this on mine soon. Not sure I need the cold climate fluid as it's not that cold here so I'll go with normal PAS fluid.
5th Oct 2021 10:25am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
Just changed mine using the syringe way over a couple of weeks, as I rarely use the FFRR (Genuine cold climate 2 ltrs). Not cheap £25 per Ltr.
5th Oct 2021 10:32am |
