![]() | Home > Maintenance & Mods (L322) > Removing cassette ball joint from the front suspension |
I'm talking about item 10 in this picture.
Anyway, I wasn't going to give up, so I made a simple tool to remove it. It's a fairly stout piece of steel channel I (badly) welded up. It's 5cm wide and I forget how long. It has a 20mm hole for the ball joint and two further holes 4cm from the central hole for some fairly sturdy bolts (24mm heads). I put some big washers in where the bolts touch the hub so as not to damage the hub.
Literally 2 minutes later...
You can see here how it was damaged by me hitting it, but it was never going to move that way.
Anyway, anyone else struggling with this I hope they find this useful. I couldn't find any off the shelf tool for removing these type of ball joints. |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 ![]() ![]() ![]() |
๐ |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35619 ![]() ![]() |
put in our wiki, thanks david.. |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1522 ![]() ![]() |
Excellent idea!! Thanks for sharing. Formerly happymadison1978 |
paul70 Member Since: 06 Mar 2018 Location: North Yorkshire Posts: 101 ![]() ![]() ![]() |
Was trying to come up with similar idea of pushing / pulling when I did mine but you've cracked it with that invention!!
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
I like to whale the living |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
That's proper!
Superspoons Member Since: 24 Jun 2010 Location: East Hertfordshire, UK Posts: 395 ![]() ![]() ![]() |
Excellent. After spending a few days getting my ball joints out this would've been invaluable |
gravitylover Member Since: 08 Nov 2020 Location: Southeast NY Posts: 36 ![]() ![]() ![]() |
FKNA yeah! You just took the fear out of what could have been a real pain in the *** job. |
Henrik07 Member Since: 14 Apr 2016 Location: Bergen Posts: 66 ![]() ![]() ![]() |
Just be warned: I tried a similar approach, only a little more sophisticated, as I had access to a fully equipped mech workshop at the time. I ground and machined a piece of steel pipe to sit over the joint, but with room for it to come out. I threaded an extension onto the balljoint stud and fed it through a bored hydraulic ram which was seated on top of the pipe. I could exert 15t of pulling power with this setup. I only needed about half that to pull the ball clean out of the socket! The socket was still frozen solid in the hub. I ended up drilling through the socket and machining a thick washer to cover the back of it, then fed a threaded bar through the whole lot with a nut at the end and pulled with the jack. It let co with a great bang in a cloud of rust-smoke.
@Henrik07 - To be honest I thought the same thing would happen - it would just pull the ball from the socket. But then it's a lot easier to get the rest of it out in the same way you describe. I can't see why you think my tool wouldn't do that also, and even if it didn't you can then easily cut it out. |
I'm not saying it wouldn't work. I'm just saying one needs to be prepared for stripped threads and other problems because of how well these things are stuck together. Having a bunch of tools and materials on hand can be the key to not getting stuck half-way through the job. Good job on a clever tool! |
Ok. |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 ![]() ![]() ![]() |
Good idea, but as some others have said too.. its not as straight forward as it sounds.
