Home > Technical (L322) > Unable to remove driveshaft from rear wheel hub :( |
mazza7282 Member Since: 10 May 2020 Location: Essex Posts: 99 |
Evening all
15th Dec 2020 9:51pm |
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1188 |
Can you get a long prybar to put tension on the back of the hub while you tap the driveshaft? |
15th Dec 2020 10:26pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6406 |
Did you try getting some tension on with your hub puller then giving the centre bolt a decent thwack ?
15th Dec 2020 10:47pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 558 |
A friend of mine had the same issue with a Disco 3 hub.
16th Dec 2020 12:23am |
Bigbo that sounds like a great idea, but I don't have any fabrication equipment at home...nor have I ever tried it infact (doh !)
16th Dec 2020 12:31am |
We broke the biggest one that Machinemart sold at the time, I think you may have the same problem.
16th Dec 2020 12:43am |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16248 |
If you need one and wish to buy the JLR tool BUT made much better! Send me a PM sir...
16th Dec 2020 12:49am |
Pretty sure cam-tech-craig's will be prettier than mine! Range Rover 4.2 Supercharged 2006
16th Dec 2020 12:59am |
And his tool!
16th Dec 2020 1:08am |
Aye doesnt have to be pretty
16th Dec 2020 1:26am |
400-ascona Member Since: 25 Jan 2018 Location: Midlands Posts: 65 |
16th Dec 2020 5:27pm |
That looks like a bit of kit there, as long as it did the job
16th Dec 2020 8:37pm |
Right, a little update.
19th Dec 2020 1:58am |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
If you can see the bolt shaft, then you may be able to use a hacksaw blade to cut through it. It won't be easy & will take some time. You're probably on the right track of removing the Hub & drive shaft together.
19th Dec 2020 10:35am |
