Home > Technical (L322) > Unable to remove driveshaft from rear wheel hub :(
Page 1 of 3 123>
mazza7282
United Kingdom 2003 Range Rover SE Td6 Adriatic Blue
Evening all
After lots of swearing/WD40 and heat. I have finally been able to remove the lower wheel knuckle bolts from this 190.000 old girl.The Wheel hub nut eventually came away (with persuasion)
I had to use a combination of wd40, heat, an air gun and a breaker bar to gently remove this bolt. Not to mention I sprayed the bolt the night before as well.
But now I have spent the last 4 hours trying to separate the driveshaft from the splines in the rear hub without success. I tried not to be over selous in hitting the end of the driveshaft but i did get carried away a little (was able to sort the threads out). My usual Hub puller isn't up to the job as the offset doesn't match up
https://www.ebay.co.uk/itm/Wheel-Hub-Pulle...%3A2334524
The official tool is here
https://jlrequipment.service-solutions.com...KU=205-857
But can anyone recommend a decent one for this vehicle, and i'll go and get one tomorrow.
All I want to do is replace the CV boot but i've been fart assing around most of the afternoon/evening with it Sad
Not to mention the small rectangular holes the handbrake shoe springs go into has rusted away, it disintegrated as I removed the rear handbrake shoes Sad
Post #576286 15th Dec 2020 9:51pm
kevinp
Can you get a long prybar to put tension on the back of the hub while you tap the driveshaft?
Post #576288 15th Dec 2020 10:26pm
Did you try getting some tension on with your hub puller then giving the centre bolt a decent thwack ?
I found this with the rear inner wishbone bushes, tension up with the bush press kit, then thwack the outside of the wishbone where the bush is. Gets it moving.... .
Post #576293 15th Dec 2020 10:47pm
mazza7282
Truth be told - I ended up getting a 4lb hammer and smashing the $%&*$£!! out of it but it didn't move a muscle.
I ended up having to sort out the threads on the shaft itself as they mushroomed a bit Sad. I expected this would happen but I started to get frustrated with it. I just don't see how it isn't moving with the 4lb hammer myself ?? I guess its just that age old rust.
I did use my favourite screwdriver (similar to a small pry tool) that I use for prying tasks, but granted I didn't use the screwdriver to pry whilst hammering so I'll try this tomorrow.
I have read elsewhere that one guy removed the driveshaft from the diff and pulled it that way because he was having trouble as well. I also saw a youtube vid of a guy using a numatic hammer on a Rangie sport rear hub, seemed to come out in seconds....I am not so lucky.
Any ideas what I could do in relation to those brake shoe pins, I might get away with 1 but the otherside, the hole will be too big to support the pin....maybe a washer or new but and bolt combo ?
Post #576301 15th Dec 2020 11:18pm
bigbo
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
A friend of mine had the same issue with a Disco 3 hub.
He booked it into the Main Dealer as he needed it done quickly they failed to get it off.
So the answer was simple make a substantial puller, I got some 1/2" steel plate and we fabricated one. I will try and get a picture of the puller if I can.
Basically it fitted over the wheel studs using the cars own wheel nuts, a collar made from the same steel was welded onto that plate and another plate welded to that, so it was kind of hat shaped. On the top we welded a large nut (under the hat top).
A large bolt was shaped so that it wouldn't damage the shaft. A very long breaker bar later soon pulled the hub off.
I'll never go to a main dealer again is the lesson I learned from that. Range Rover 4.2 Supercharged 2006
Ford Focus EcoBoost 1.5 2017
MG TF 2003
Previous Cars of note
Land Rover Discovery 2
Jaguar Mk2 3.8 - Company car
MG Midget 1974 - Concours
Post #576303 16th Dec 2020 12:23am
mazza7282
Bigbo that sounds like a great idea, but I don't have any fabrication equipment at home...nor have I ever tried it infact (doh !)
So I would be unable to proceed.
I'm thinking of trying the larger of the 3 pullers out here. Maybe I can wrap it round the wheel bearing and push the centre nut directly onto the driveshaft.
https://www.toolstation.com/gear-puller-se...DrEALw_wcB
Post #576304 16th Dec 2020 12:31am
bigbo
We broke the biggest one that Machinemart sold at the time, I think you may have the same problem.
Any blacksmith or engineering workshop should be able to knock one up.
The only tools we used were Oxyacetylene cutter, stick welder and a grinder.
The collar we heated to red hot and hammered it around a former (don't remember what we used)
So all pretty agricultural, maybe a local farmer? Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #576305 16th Dec 2020 12:43am
If you need one and wish to buy the JLR tool BUT made much better! Send me a PM sir...
I borrowed one from a JLR main agent and took it to out specialist tool makers, he took one look at it and said "i can make a much better job of that!"
So we had to have several tools made as he had to order an amount of a specalist metal?
So, i have one in the workshop and ive used the same one since 2008! And its never failed to shift a shaft!
Im sure we have 3 or 4 left... Thumbs Up
Post #576306 16th Dec 2020 12:49am
bigbo
Pretty sure cam-tech-craig's will be prettier than mine! Thumbs Up Range Rover 4.2 Supercharged 2006
MG TF 2003
Post #576307 16th Dec 2020 12:59am
And his tool! Thud
Laughing Rolling with laughter Bow down Thumbs Up
Post #576308 16th Dec 2020 1:08am
mazza7282
Aye doesnt have to be pretty Laughing
Just has to do the friggin job :p......ive sent a PM Smile
I do have an engineering shop near me actually. I guess if i got something to them they might b able to sort something.
Ive taken the negative off the batt and shut the door now on the car so it doesnt decide to adjust its ride height.
Guess ill get back to it, when i get back to it
Was a nice sunny day today aswell plenty of light (until 21:00 when I came back in again!)
Post #576310 16th Dec 2020 1:26am
400-ascona
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Java Black
Admittedly its for the front, but I made this and still ended up having to use a chisel to hit the outer diameter of the drive shaft knuckle housing so I fitted new ends on the driveshafts. 05 L322 4.2SC
2016 Discovery 4 Graphite
Lotus Carlton
Ascona 400
Volvo V70R AWD manual
Suzuki 1200 Bandit
Velocette Venom
BMW R80/7
Daimler V8 250
Mini Cooper S Works 2006
Post #576353 16th Dec 2020 5:27pm
mazza7282
That looks like a bit of kit there, as long as it did the job Smile
Unfortunately i’ve had to give up....I just cant shift it with the appropriate toolage this time (A decent puller)
-The large puller from tookstation didnt work (yea, yea .... I know I was told it wouldnt)
-As I was smashing the driveshaft into the hub (occasionally hitting the hub). The wheel is now a right pain in the ass to put back on coz the outer ring is now slightly deformed (great—-now a new hub unless I can smash it back)
- I ran outa gas in the blow torch and ive used almost an entire can of WD40 (on top of the overnight soak)
I also did try to remove the upper (as i already have removed the the lower) arm bolt. But that one totally refused
to move so ive had enough.
First time for everything I suppose, so ive booked it into my MOT garage who I use, told them whats gone on and they say there gonna try n give it a go.
Post #576396 16th Dec 2020 8:37pm
mazza7282
Right, a little update.
I decided to give this one more crack. What failed to mention is that I decided to remove the calier & disc to see if it would make removal easier by adding wd40 in a few more places.
In removal of the disc is the handbrake shoes came flying out as the backing plate is totally rusty & someone else has used small nuts/bolts n washers. Did a search on FFRR and seen its a common fault.
Rather than buy a brand new one from Land Rover (£75 inc vat each) + cutting it in 1/2 and re-stitching it over the hub (or remove the hub) I took advise from another thread on this forum and looked to get brake show repair kit from another car and use the buttons as backplate fillers.
Seems to work well, I couldnt get the new shoes in the drum (even tho they were the same as to what came off, it wouldnt gave it... despite the adjuster being all the way in so I gave up and put the old shoes back and ajusted it up nice.They had about 1/2 life left in anyway....a bosch part.
Afyer buying a new botttle of gas and heating the top wheel knucke bolt super hot (not oxy hot but hot!) in order to loosen that. I got the breaker bar out and added force gradually, it only bloody started moving a bit !! -
Then it snapped ....
My plan was to loosen that bolt and remove the shaft from the diff end, then try remove the shaft again (more carefully than last time!) and see if that works.
So now the handbrake is re-assembled & ive rammed a bit of RTV into the cv boot as a temp measure.
How on earth is this bolt gonna come out then ?? I did try to get a 18mm on the other end thinking .....hopefully now the nut off, it would undo .....err no Big Cry
Post #576566 19th Dec 2020 1:58am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
If you can see the bolt shaft, then you may be able to use a hacksaw blade to cut through it. It won't be easy & will take some time. You're probably on the right track of removing the Hub & drive shaft together.
You could then take them to your local Engineering shop to separate Thumbs Up
Post #576578 19th Dec 2020 10:35am
Page 1 of 3 123>
