Home > Technical (L322) > Sudden heavy stearing
Oddvar.L
Norway
My wife was out driving the fatty today, an as she entered a raundaboat the stearing wheel was wery heavy/stiff. I have asked hear if the engine stopped, she say no.
She stopped shortly after, and after her shopping round, al was normal again.
Have been out for a test run, al seems normal. Have anyone heard of simmilar things in this cars? 2007 tdV8
Post #576478 17th Dec 2020 8:41pm
CS
My 2004 4.4 got heavy steering when the power steering pump was failing, but not so on/off. But tight lower speed turns would be where one would notice it most.
I assume you have checked tyre pressures? Again with that car when I had to drive for some distance with a flat Goodyear MT/R on one side at the front it steered fine most of the time, but slow and heavy on tight turns. The sidewalls on those tyres were strong enough to stand that, it might not be the same with more normal ones.
Another possibility might be a brake caliper sticking. That also happened on that car, when the pads had recently been changed and presumably the corroded outer section of the caliper piston pushed back in. Only Range Rovers since 1988
Post #576518 18th Dec 2020 12:29pm
Ricardo Villa
United Kingdom 2009 Range Rover Vogue TDV8 Bournville
This happened on my Jaguar when battery was low, not sure if it's applicable to the RR. 2009 Range Rover Vogue 3.6TDV8, Bournville, Parchment/Navy
2005 Jaguar XJ350 3.0 V6 Sovereign, Jaguar Racing Green, Ivory
1997 TVR Chimaera 450, Formula Red, Grey
Post #576521 18th Dec 2020 12:32pm
Gsxr1250dave
Yes if that battery is low it happens on the range rover mine did it a couple of times before I swopped out the battery
Post #576525 18th Dec 2020 1:03pm
Oddvar.L
Norway
Thank You all for response. Tyre pressure ok.
Breake caliper, yeah, maybe. Have heard noise from right front one couple of times.
Will take a closer look.
Battery voltage was a little low at 12.1V before I started for test drive.
Will put charger on as a matter of c.
By the way, book say to disconneckt battery from car, before charging.
Never bothered with that on any cars I have owned? But this is by far the most complicated car I have owned.
Think I'l do that. What do You do when charging.
Post #576530 18th Dec 2020 2:26pm
kevinp
Presume you've checked the power steering fluid level?
Post #576531 18th Dec 2020 2:39pm
Oddvar.L
Norway
Jupp🙂
Post #576534 18th Dec 2020 3:42pm
failing servotronic valve or bcm, loads re those on the forum... Thumbs Up ... - .- -.
Post #576546 18th Dec 2020 5:30pm
Oddvar.L
Norway
Thanx🙂👍
Post #576555 18th Dec 2020 7:22pm
Bantam
2007 Range Rover Vogue SE TDV8 Java Black
Bad connection
There is a wire connection that can break on the Valve - was resoldered when it happenned to me & been fine for 5 yrs
Post #576889 21st Dec 2020 9:21pm
Oddvar.L
Norway
My wife said there came a message in the info senter in the speedo, but unfortinally, she's not that used to reading English, and she was rather stressed trying to get thru the roandaboat not hitting the curbs.
However, the car has been flawless ever since🙂
Post #576908 22nd Dec 2020 12:08am
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
my car had a similar problem which was caused by a failing alternator!
https://www.fullfatrr.com/forum/topic56572.html
Post #576945 22nd Dec 2020 11:05am
Oddvar.L
Norway
Ok, I have noticed the alternator do take some time after startup, before charging correctly. Dont know if thats a bad sign🤔
Post #577054 23rd Dec 2020 9:13am
