Home > Technical (L405) > Air Suspension Pipe Needed
Chunk72
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Hi All,
So today I jumped in the car to discover that it was stuck in access mode and doing all sorts of wonderful things which did not make for a fun start to the day.
After the school run I opened the bonnet to investigate and discovered a delightful Censored rodent has chewed not 1 but 2 holes in the air pipe that connects the drivers side strut to the distribution block.
Fingers crossed but this is all the damage I could see.
Any idea what the part number is and is it going to be a dealer only part?
Cheers
Post #576323 16th Dec 2020 11:11am
you could look in the microcat links in the wiki for the part number or email robin at our forum sponsor , duckworths..
robinhall@duckworth.co.uk ... - .- -.
Post #576331 16th Dec 2020 12:28pm
andygts
If it is the plastic pvc stuff thats been chewed you could save yourself a fortune and go to a hose specialist such as pirtek or a local place and buy a couple of push fit joiners and a small length of pipe, if it has enough excess you might get away with just one joiner.
eg
https://uk.rs-online.com/web/p/pneumatic-s...s/9160873/ Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #576334 16th Dec 2020 12:52pm
Chunk72
Thanks both, ordered from dealer for delivery tomorrow £99! Shocked
Now planning how to pest proof my parking area, seems 3 bait boxes aren’t sufficient.
Post #576336 16th Dec 2020 1:12pm
Chunk72
Coming back to this in case anyone needs the information in the future,
Part number for the Front Air Suspension Pipes is LR122994 comes as a set so both sides are in the bag.
Description is Tube - Air Suspension and Team Valley Land Rover did them for £99.92 totally overpriced for what they are.
It took 5 mins and a 12mm spanner to fit, piece of cake.
In future any 6mm pvc pipe would have done as the fittings are reusable if you are careful with the brass collets.
Post #576593 19th Dec 2020 1:55pm
