Home > Maintenance & Mods (L405) > Charging system fault
Mca71
A week or so I got a charging system full error, which has now gone, but getting continuous low battery messages now on my two year old 405. Auto close in the boot not working, etc .Can’t believe I’m getting errors like this on a two year old car. Any ideas?
Post #576019 13th Dec 2020 7:57pm
can you fill in your car profile please, it'll help with answering your question.. ... - .- -.
Post #576022 13th Dec 2020 8:07pm
AnotherMutley
Had Charging Fault on mine after 2 months of ownership, LRA found the Gateway module running a low level of code, upgraded it, not seen it since.
Post #576105 14th Dec 2020 11:42am
Arch Stanton
England 2018 Range Rover Autobiography SDV8 Corris Grey
Happy old thread bump.
My 2018MY of 3 days ownership is showing a charging system fault, I need to go 50 miles the other way to the dealers in the morning, how likely is it to let me down?
Tailgate is working fine under its own steam as that seems to a barometer of battery condition (it hashed good few runs in the last few days as I've been going the long way everywhere) First time FFRR owner
Post #653915 18th Jan 2023 5:22pm
AnotherMutley
If you've got a mulitmeter, take a reading from the battery when the cars running, anything from 13 volts upwards is good.
Don't know whether you bought it from an franchised dealer or not, if you did it should have an LR warranty, call LR assist they'll come out and read the codes and upgrade any modules that are down revision.
Post #653918 18th Jan 2023 5:57pm
Arch Stanton
cheers mutely, I forgot about LR assist.I'll get a MM on it in a bit First time FFRR owner
Post #653920 18th Jan 2023 6:06pm
Arch Stanton
Checked the voltages, engine not running, battery is at 12.36v which I thought may be a touch low, engine running it was at 15.2v which I thought maybe a bit high.
Hopefully this means it can go back and be mended in more slow time than on the back of a truck of shame. First time FFRR owner
Post #653929 18th Jan 2023 6:54pm
grayst01
Scotland 2012 Range Rover Vogue 4.4 V8 Java Black
*old thread bump Thumbs Up
Just had this fault show up on the L322 (2012 4.4). First felt a loss of power steering and then the ‘charging system faulty’ showed up along with restricted performance and red battery icon on the dash.
I was 20 miles from home at the time and decided to chance it either home or to the local Indy in town hoping the battery wouldn’t die. It did get me to the garage where I’ve parked it up for them to hopefully get to it asap this week. Did give me a good workout on the arms for sure!!
Using the GAP tool it showed voltage down at 11.5v when I stopped and had restarted the engine, so I’m glad I took it straight there rather than home and chance another drive out to them.
So my thoughts initially are: is this likely the alternator? If so, can anyone advise on approx costs/labour hours to do this job and if it is alternator are there other jobs i should consider doing at this time being in there?
Thumbs Up in advance… Cheers, Steven.
2012 Vogue 4.4 TDV8.
Post #697020 28th Jul 2024 11:15am
