![]() | Home > Maintenance & Mods (L405) > Charging system fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35628 ![]() ![]() |
can you fill in your car profile please, it'll help with answering your question.. ... - .- -.
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 ![]() ![]() |
Had Charging Fault on mine after 2 months of ownership, LRA found the Gateway module running a low level of code, upgraded it, not seen it since. |
Arch Stanton Member Since: 26 Apr 2012 Location: chavshire Posts: 511 ![]() ![]() ![]() |
Happy old thread bump.
If you've got a mulitmeter, take a reading from the battery when the cars running, anything from 13 volts upwards is good.
cheers mutely, I forgot about LR assist.I'll get a MM on it in a bit First time FFRR owner |
Checked the voltages, engine not running, battery is at 12.36v which I thought may be a touch low, engine running it was at 15.2v which I thought maybe a bit high.
grayst01 Member Since: 08 May 2022 Location: Glasgow Posts: 105 ![]() ![]() ![]() |
*old thread bump |
