Home > General > What Did You Do In Your Full Fat Today |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 347 |
Sprained my ankle hiking, meaning I can't ride my Mountain Bike in the forest so... thought I'd go "ride" the trails in the fatty instead!
9th Dec 2020 12:59pm |
bigbo Member Since: 07 Jul 2014 Location: Derbyshire Posts: 589 |
Took mine for an MOT this morning, unfortunately it failed on emissions, that surprised me I must admit.
10th Dec 2020 1:16pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35412 |
filled mine with diesel, only second time since march.. ... - .- -.
10th Dec 2020 1:24pm |
Red Hot one Member Since: 09 Dec 2018 Location: Herefordshire Posts: 184 |
Had an MOT, only one advisory, rear axle bushes perished, well pleased with passing, will look at the bushes later. |
11th Dec 2020 10:18am |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 |
got new projector puddle lamps to fit will post a pic later 2012 Vogue 4.4 TDV8 - Current
11th Dec 2020 12:42pm |
Cleaned it today, snowfoam etc. Then did the ceramic coating, hoping it will now be easier to clean and stay cleaner for longer.
12th Dec 2020 10:34am |
luxmoggy Member Since: 19 Jun 2020 Location: Trier Posts: 469 |
I can confirm that the car is easier to clean after the Ceramic coating... last week... pressure-wash the large lumps of mud... snow foam... rinse and dry... and it shines... the longest part was the drying it using the Microfibre clothes... SDV8 AB MY 2020
12th Dec 2020 10:46am |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3836 |
Jet washed all the mud off. Geoff |
12th Dec 2020 3:53pm |
Thanks guys, will let you know how it goes.
13th Dec 2020 7:18am |
JoolsB Member Since: 16 Aug 2020 Location: The North Posts: 284 |
Got it open, got it started and went for a lovely drive, reminded me why I bother.
13th Dec 2020 5:38pm |
Bean19844 Member Since: 25 Oct 2020 Location: Essex Posts: 929 |
Well I picked mine up from the garage. Done the passenger side step but I couldn't do the driver side step. Garage called me up n said they can do it but they would have to weld it to the existing brackets where the old one was cut off. I've managed to stand on the side step n it holds me n I weigh 24 stone so holds a good 155kg with no trouble |
13th Dec 2020 10:47pm |
Finally fitted the front drop links that I bought in September. What a difference, no rumbles or rattles at all., drives like a Range Rover should.
19th Dec 2020 3:36pm |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3241 |
Fitted new battery. Went with Varta l1 (020) which was the same as the one I was replacing. Did have to "modify" it slightly. John
20th Dec 2020 11:33am |
Took it for a quick spin having changed the gearbox oil and Mechatronic sleeve, nerve wrecking to get the sleeve out and back in again, not quite 5 l oil out, 5.8 l back in, changing gears beautifully and no leaks (so far), will try and get some more oil in when it's cooled down. |
20th Dec 2020 3:38pm |
