Home > Maintenance & Mods (L322) > Parasitic Battery drain culprits
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Hi, which circuits are the usual culprits( if any) for battery drain while the car is locked, so I can check those, first rather than laboriously having to pull every fuse? Thankyou. Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #573916 24th Nov 2020 1:52pm
Siftah
Spain 2011 Range Rover Vogue TDV8 Stornoway Grey
Haven't got the fuse references to hand, but I believe the usual suspects include;
- Audio Amp (gets wet and causes a short if the boot leaks)
- Hedgehog/"FSR" or "Final Stage Resistor" which is the resistor ladder that adjusts the fan speed from high down to low, this breaks down and causes a load.
- Headlight washers, when the motors get tired they don't park properly and cause a parasitic drain.
One of these has just turned up and I'll be spending the weekend trying to sort out my parasitic drain with it too! https://www.amazon.co.uk/Shefii-Tester-Det...08CXK6NTQ/
Post #573925 24th Nov 2020 3:17pm
coopss
That looks like a very useful device! Thanks for sharing 1995 4.6 v8, green/tan (long gone)
2005 4.8iS X5, blue/black
2011 4.4 tdv8, black/black (gone)
2003 3.0d X5, Oxford green/black/manual
2021 p575 SVR, BR green/vintage tan
Post #573937 24th Nov 2020 5:05pm
Rapiscan
Thanks for the info, I'm gonna get one, seems really usefull Bow down Thumbs Up 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #573945 24th Nov 2020 5:41pm
NobbyC
United Kingdom 2005 Range Rover Vogue 4.4 V8 Buckingham Blue
I once had a constant drain which was finally tracked down to corrosion inside the tow sockets.
Post #573955 24th Nov 2020 7:13pm
Rapiscan
Wow! Who would have thought to consider those? Not me for sure, thanks for the heads up. 👍 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #573986 24th Nov 2020 9:30pm
Ian G
United Kingdom 2003 Range Rover HSE Td6 Epsom Green
I had FSR failure on mine but not such a mystery to diagnose, it was making so much noise the neighbour knocked to say it was keeping him awake.
Post #574000 24th Nov 2020 11:58pm
Siftah
I didn't get around to checking over the weekend, but I just walked past the car this evening and notice the screen (drivers info screen) was on!
Nothing showing on the screen, but the backlight is on and you can see it brightening and dimming in response to the light level changing.
So that's probably the culprit of my mystery battery drain found! Smile
Post #574676 30th Nov 2020 7:49pm
Siftah
As an update, sort of found what's causing my 0.2amp drain, details in this thread: https://www.fullfatrr.com/forum/topic57611.html
Post #575484 8th Dec 2020 12:58pm
D3Jon
Siftah wrote:
<snip> One of these has just turned up and I'll be spending the weekend trying to sort out my parasitic drain with it too! https://www.amazon.co.uk/Shefii-Tester-Det...08CXK6NTQ/
What a great idea, just gone on my wishlist!
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #575491 8th Dec 2020 2:24pm
Siftah
Yeah, have a look at this model too, it does the small "mini blade fuse" that you get in the later fuseboxes!
https://www.amazon.co.uk/BGS-Digital-Ammet...00871YGJ0/
Post #575494 8th Dec 2020 2:58pm
Rapiscan
If you place a stamp sized piece of tissue paper over the little grill containing a tiny fan for the HVAC you should find it is held in place by the suction of the fan, when your turn off the engine and lock the car, after approx 15 mins the tissue should fall off indicating the fan has, shut down therefore no suction, if it remains in place then its likely the fan is, still running albeit silently and drawing current.. 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
Post #575506 8th Dec 2020 5:32pm
Siftah
I went with the current meter, luckily, as the drain comes back after a few hours so the tissue probably wouldn't have helped! Smile
Post #575560 9th Dec 2020 1:02pm
