Home > Technical (L322) > Reverb buzz vibration sound.
Gr4h4m
United Kingdom 2010 Range Rover Vogue SE 4.4 V8 Santorini Black
Hi all I have a 4.4tdv8 on a very late 2010. I have a strange noise when at low revs/light throttle. The car makes a reverb or vibration sound, but you don’t feel a vibration. If you press the accelerator a little more it goes away. I never feel it at high speed or at idle?
Any ideas, my local gut I take it too have broken his leg so is out of action for a few weeks.
Any thoughts, it’s a hard noise to describe? I wondered if it could be a heat shield or similar, I never noticed it when I test drove the car and they had the bottom arms changed as part of the service I don’t tknowif there is anything that might of been removed to gain access that might vibrate like an under shield?
Thanks for any help
Post #575006 3rd Dec 2020 9:10pm
Discotigger
Strange, I've recently started to get a similar noise after a full service and some work on the brake lines. I get a vibration noise at low revs when under slight load, sounds a little bit like a vibration (buzzing sound) through a plastic drainpipe (if that makes any sense) which seems to be getting a bit louder and more frequent. No noises at all if I put my foot down a bit, but appears under gentle load or when slowing down in slow moving town traffic. I'm thinking either a loose heat shield or something (like a pipe) not secured properly. I've had a quick look under the fattie but can't see anything obvious, may take her backtothe garage and get them to have a look.
Anyone got any ideas or advice where or what to look at.
Post #575040 4th Dec 2020 10:01am
cass
I'd bet on the heat shields, I've just done the brakepipes on my 2011 and while I was under there I found that practically every shield had corroded through some of or in one case allof the fastener holes.
If nowt else it's a cheap place to start!
Post #575049 4th Dec 2020 11:14am
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Yep usually the heatshield above the prop shaft near the front. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #575053 4th Dec 2020 12:47pm
Gr4h4m
Thanks all time to get dirty under the car at the weekend. What do people generally do to them? Remove or replace
Post #575060 4th Dec 2020 1:32pm
Discotigger
You will need to refit the heatshield with new Heatshield nuts.
Part no. for the nuts is: WYH500050
Just ordered some for myself, cost between £1.75 to £4.00 each approx.
Post #575065 4th Dec 2020 2:36pm
cass
The "correct" answer is to refit them - large washers and new nuts generally does the trick however I've got a 3.6 which has had most of the shields removed several years ago and it suffers no ill effect but it hasn't got a DPF generating very high temperatures.
There are some that I wouldn't dream of removing due to the routing of the exhaust/DPF but others look a bit OTT.
So I suppose the short (and not very helpful) answer is "It depends"
Post #575077 4th Dec 2020 4:33pm
