Home > Technical (L405) > Oil sump drain bolt seized
Ahem, i think you'll find they were designed to have the oil drained from below when they were fitted to some Americans truck! They were never designed to drop the oil in a JLR product! Ner Ner
Post #575028 3rd Dec 2020 11:22pm
knwatkins
The presence of a a sump plug has nothing to do with the fact it was earmarked for the F150.
The Land Rover service manual even states that draining via the sump is a valid method.
The engine is designed to have the oil drained via either methods, irrespective of what vehicle the engine is fitted into.
Likewise, the Ingenium engines, used exclusively in JLR vehicles have both a sump plug and oil suction tube. They are designed for both. Kev
2014 L405 RR Vogue SE 4.4 SDV8 in Corris Grey
2010 L320 RRS HSE 3.0 TDV6 in Stornoway Grey
Post #575038 4th Dec 2020 2:54am
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
Besides how else would you know the sump guard can come off. I swear it would've tested an Angel! Call me old fashioned but don't feel I know a motor until I've dropped the oil and had a look under her skirtšŸ˜Œ Help got CAR OWNER VIRUS!
Post #575296 6th Dec 2020 9:03pm
Had the sump guard off mine. It came off Ok.
But for a service I would just suck it out. Very little more will drain down once itā€™s sucked out. Even if there is 1/8 litre it should make very little difference given that you are putting around 9 1/2 litres in.... about 1 1/2% old oil in 98.5% new oil.... There is nothing that can't be fixed with a hammeršŸ˜œšŸ˜œ
Post #575305 6th Dec 2020 9:57pm
Gremlin500
ā€¦ā€¦ā€¦ā€¦ ā€œIf it ainā€™t broke, donā€™t fix itā€ -whereā€™s the fun in that?
Post #627571 1st Apr 2022 11:33pm
oggy
United Kingdom 2007 Range Rover Vogue SE 4.2 SC V8 Java Black
get the mig out and weld a nut on . or get someone with a good socket and bar on nut and then give the flange of the bolt a hit with a chisel and hammer it has no mother or father so vidde hit the sod . new vehicle purchase
2007 supercharged 4.2 java black .sand leather vogue se trim
previous cars .
range rover classic 200 tdi
discovery 1 200 tdi
freelander 2 2008 hse
discovery 1 300 tdi
p38 4.0 ltr man r380 ex royal support vehicle on v5c
discovery td5 man off roader
Post #627680 3rd Apr 2022 7:58pm
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
knwatkins wrote:
Cam-Tech-Craig wrote:
To be fair, JLR made/installed the service tube to suck the oil out... They were never designed to drop the oil out from below... Thumbs Up
It's worth mentioning that in marine engines, the oil is always sucked out because there is no way to drop it out from below. It is a safe enough method of changing the oil.
Not quite true. My 3.0 Mercrusier had a rubber pipe attached to the drain plug. The pipe would reach through the bilge drain plug and the sump could be emptied via the tube. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #627688 4th Apr 2022 6:31am
