Home > Technical (L405) > Air Suspension Height Changes
Jase71
Australia 2017 Range Rover Vogue TDV6 Santorini Black
Quick one guys, if I leave the car in normal height when parked overnight and then when I restart (without having moved) and notice the car making small height change corrections, is that normal or is it an indication of loss of air pressure overnight? Thanks in advance for any ideas! 2017 Range Rover Vogue V6 Diesel
2006 Range Rover Vogue V8 Diesel - gone
Post #574980 3rd Dec 2020 6:34pm
mine does that slightly if i park on an uneven surface..only a small adjustment... Thumbs Up ... - .- -.
Post #574981 3rd Dec 2020 6:37pm
Jase71
I'm guessing if pressure was being lost Stan a warning light would illuminate? 2017 Range Rover Vogue V6 Diesel
Post #574990 3rd Dec 2020 6:48pm
Crasher242
Mine does this too.
Only slightly mind you.
I put it down to the unevenness of our drive (it has a slight diagonal slope away from the buildings to the trackway).
I've tended to put it into access mode now when I park up, especially if I know the car will probably be sat for a week before its next outing Smile Current
Vogue SE 4.4 SDV8
Previous highlights
Many Mini's!
Audi S8
Audi A6 Avant (the petrol guzzling Bi-turbo)
Subaru H6 3.0 Estate
Peugeot 406 Coupe V6
Audi 80 Quattro Sport
Post #575087 4th Dec 2020 6:01pm
Jase71
interesting...my drive is flat so its must be very sensitive. I also wondered whether access height was best for the car when left for a week or two versus leaving in standard height.
I tend to leave my car in standard height as inconsiderate peoples doors have less ability to place a dent in the car! 2017 Range Rover Vogue V6 Diesel
Post #575090 4th Dec 2020 6:10pm
marcochezzi
South Africa 2011 Range Rover Vogue SE 5.0 SC V8 Fuji White
My 2014 405 parks in the garage all day, perfectly flat, still drops the nose slightly..
My 2011 322 did this very thing, with new front airstruts, and new front control valve block..
I do not bother about this any longer, until the day I find her nose on the stops, then I will worry..
Post #575323 7th Dec 2020 7:08am
Jase71
That's good to hear. Probably not worth me being charged to find any issues if it's normal then. Could get quite expensive. Just don't remember the car doing it when new.. 2017 Range Rover Vogue V6 Diesel
Post #575345 7th Dec 2020 11:58am
Jase71
I'd certainly like to understand how the system works better. I've seen the rear of the car move when its just been turned off..you'd think with the ignition off no more adjustments would occur. But I've seen small corrections. 2017 Range Rover Vogue V6 Diesel
Post #575385 7th Dec 2020 4:48pm
this should help explain it a bit,
https://www.fullfatrr.com/gallery/albums/u...TION~1.pdf ... - .- -.
Post #575388 7th Dec 2020 5:01pm
Jase71
Thanks Stan Thumbs Up 2017 Range Rover Vogue V6 Diesel
Post #575391 7th Dec 2020 5:17pm
Jase71
This answers the question in the operation description:
Periodic Re-levelling
When the vehicle is parked, the Integrated Suspension Control Module
'wakes up' two hours after the ignition was last switched off and then once
every twenty four hours. The vehicle height is checked and if the vehicle is
not level within a pre-set tolerance, small downwards height adjustments
may be made automatically
So it is normal! Didn't know it did that when off. 2017 Range Rover Vogue V6 Diesel
Post #575393 7th Dec 2020 5:26pm
i dont know why it would want to do that but its all very clever stuff... ... - .- -.
Post #575394 7th Dec 2020 5:30pm
Jase71
Just when I had convinced myself and now I'm worried again!
started up yesterday (afetr leaving in standard height) and the front height popped up again to level itself (probably half an inch) on completely level ground. Has anybody else had this? My car is 017 with 70k miles now.
Thanks in advance. I don't ever remember it doing it before.
Has Camtech Craig seen this on L405's? 2017 Range Rover Vogue V6 Diesel
Post #575462 8th Dec 2020 11:29am
marcochezzi
Jase71, yes, 100%, as I mentioned in my previous post, my garage is perfectly flat, she still dips..
1/2" is nothing, 2" or more I would look for what-ifs...
Post #575514 8th Dec 2020 8:40pm
Jase71
Has anyone confirmed there are no leaks or faults? Has yours always done that? 2017 Range Rover Vogue V6 Diesel
Post #575515 8th Dec 2020 8:43pm
