![]() | Home > Technical (L405) > Air Suspension Height Changes |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35482 ![]() ![]() |
mine does that slightly if i park on an uneven surface..only a small adjustment... |
Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 490 ![]() ![]() ![]() |
I'm guessing if pressure was being lost Stan a warning light would illuminate? 2017 Range Rover Vogue V6 Diesel
Crasher242 Member Since: 07 Mar 2019 Location: Warwickshire Posts: 136 ![]() ![]() ![]() |
Mine does this too.
interesting...my drive is flat so its must be very sensitive. I also wondered whether access height was best for the car when left for a week or two versus leaving in standard height.
marcochezzi Member Since: 19 Jun 2016 Location: Johannesburg Posts: 96 ![]() ![]() ![]() |
My 2014 405 parks in the garage all day, perfectly flat, still drops the nose slightly..
That's good to hear. Probably not worth me being charged to find any issues if it's normal then. Could get quite expensive. Just don't remember the car doing it when new.. 2017 Range Rover Vogue V6 Diesel
I'd certainly like to understand how the system works better. I've seen the rear of the car move when its just been turned off..you'd think with the ignition off no more adjustments would occur. But I've seen small corrections. 2017 Range Rover Vogue V6 Diesel
this should help explain it a bit,
Thanks Stan |
This answers the question in the operation description:
i dont know why it would want to do that but its all very clever stuff... ... - .- -.
Just when I had convinced myself and now I'm worried again!
Jase71, yes, 100%, as I mentioned in my previous post, my garage is perfectly flat, she still dips..
Has anyone confirmed there are no leaks or faults? Has yours always done that? 2017 Range Rover Vogue V6 Diesel
