![]() | Home > Maintenance & Mods (L322) > 3.6 TDV8 A/C compressor replacement |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 ![]() ![]() |
What are the symptoms? Your AC tech should be able to tell if the clutch on the AC compressor is engaging and what the pressures are doing, if you don’t have leaks and the pump is working, it’s more likely to be your expansion control valve which is located I believe under the dash on the side of the evaporator core.
HS66 Member Since: 22 Jun 2016 Location: Surrey Posts: 73 ![]() ![]() ![]() |
Regassed once and all fine, holding a vacuum and pressure before degassing, AC blew ice cold for a couple of weeks then stopped working, checked in gauges etc and no gas, second time pressure tested with the specialist, not just a standard regass, whole system was showing fine, he checked and no leaks present and was quite thorough, regassed and put some extra oils which can help o rings etc in?, and said to run it on full cold for 30 ish mins a day for 2 weeks to allow it to penetrate the whole system properly, after about day 10 again not blowing very cold, gas low again, he thinks it can only be an issue with the compressor now?, leaking internally.
If you are loosing gas do a UV dye check, it will show where the leak is... most likely the evaporator then next likely the condenser. Note you can see the evaporator but will find the dye in the water drain under the car.
P.S I used to be a master tech but also fully trained by AutoClimate in Shrewsbury who design and make AC solutions for OEM as well as training for technicians 👍 |
Thanks for your reply and help |
You don’t want to leave it, moisture in the system causes corrosion and can stop the system functioning as it freezes the expansion control valve.
I had it in for some other work and the guy spotted a leak in one of the pipes, must be quite a small one I’d guess to not pick it up on a pressure test but it’s in the pipe that runs from the condenser to the compressor, not sure how tricky it would be to replace. |
