Home > Technical (L322) > New AC needed?
NDT
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
New AC needed?
Having had no operating AC for months I've finally had it checked by my local independent.
They think it's the compressor rather than the DPS valve - based on wanting to have a look at the compressor first.
They were iffy about being able to get a replacement DPS valve.
Does this ring true? I was under the impression that most of the compressor failures were just the DPS valve.
Final question... amount of time to swap the compressor - they're talking about having to drop subframe slightly to get at it?
Post #571871 4th Nov 2020 5:58pm
DrRob
I’m quietly researching this myself as I get a delay to cold in hot weather. Do I go valve or complete compressor? Whistle Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #571874 4th Nov 2020 6:54pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
Isn’t this quite a well known issue on late TDV8s? I nick-named it ‘Vario-Air’ on ours, not so funny in the Spanish summer...
Mine did this last year. Suspected culprit is the sensor on the compressor, not the actual compressor mechanicals. Just replace the compressor as it’s not worth the labour not too. By the time you’ve reached the sensor etc.
It’s the same issue on a lot of VAG products, as it’s the same part.
I’ve got my old compressor and will replace the sensor and have it as a potential backup for next time. 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #571879 4th Nov 2020 7:23pm
NDT
I don't think my aircon is working at all - even on a long (over an hour) journey.
Tending to think the whole compressor might be shagged, not just the valve.
Post #574746 1st Dec 2020 11:16am
maric995
Croatia 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Can anyone tell me what are the symptomes when that valve goes? My aircon worked this summer on shorter journeys around town, but when I was driving on longer journeys, it would just start blowing normal not cold air, after switching car off and on, it proceeds with blowing cold. Rolling Eyes RR HSE 4.4 2006 LPG
Post #574756 1st Dec 2020 12:40pm
NDT
see also:
https://www.fullfatrr.com/forum/topic43778.html
Post #574768 1st Dec 2020 2:02pm
NDT
As I understand it, when the valve has failed there is typically a delay before the aircon starts working.
Post #574769 1st Dec 2020 2:02pm
kooky_guy
I had this problem.
My indy explained to me that the labour is the same to replace the valve as it is to replace the compressor. A replacement compressor comes with a 2 year warranty - the valve only 1.
There was only £300 in it (I think) so I went for the complete compressor). 2010 4.4 TDV8 Vogue SE
Post #574839 2nd Dec 2020 11:22am
DrRob
I raised this with Rovertune and they recommended a new compressor over just doing valve for reasons laid out above. I suspect Kooky_guy used Rovertune too Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #574854 2nd Dec 2020 1:39pm
kooky_guy
I did indeed! 2010 4.4 TDV8 Vogue SE
Post #574864 2nd Dec 2020 2:43pm
