Home > Technical (L322) > electrics not shutting down |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 |
hi folks
30th Nov 2020 11:55am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
FSR - Final Stage Resistor (hedgehog) ? .
30th Nov 2020 12:17pm |
hi joe,*
30th Nov 2020 5:42pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2641 |
It’s in the WIKI, top right of forum toolbar; https://www.fullfatrr.com/forum/topic781.h...eplacement |
30th Nov 2020 7:54pm |
ok i will take a look, thanks.
30th Nov 2020 8:22pm |
Siftah Member Since: 11 Jun 2018 Location: Barcelona Posts: 344 |
According to this article, nope, if you're having the symptom of the fan staying on after the cars locked it seems a likely culprit.
1st Dec 2020 11:48am |
hi there, well im not able to get down and the work as my joints wont allow so i need to arrange a garage to look at it, in the meantime i wil try the fuse, would it be the main blower heater fuse ,?
1st Dec 2020 3:40pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Try fuse 34.
1st Dec 2020 8:43pm |
ok i try them
1st Dec 2020 9:25pm |
So... obviously there's loads of different reasons for the battery going flat, but I've just done a battery reset on mine and I think it maybe solved my problem.
3rd Dec 2020 5:38pm |
And I should clarify, whatever the noise is inside the dash it doesn't sound like the blower fan, it's more likely, I think, to be a fan for cooling the AV system or something. I think I've read elsewhere on here that such a thing exists - though I'm struggling to find the thread again!
3rd Dec 2020 5:42pm |
Spoke too soon, just been back out to check the car and the hazard warning light is illuminated again and the backlight on the instrument cluster is back on (no picture, but you can see it's faintly lit).
3rd Dec 2020 6:20pm |
hi there
6th Dec 2020 7:08pm |
Are you also seeing the hazard warning light backlit and the screens backlight also on?
6th Dec 2020 7:32pm |
no , nothing else is showing just the whiring noise. i did notice a couple of times that it changes pitch and uns slower with a sort of pulsing effect !!
6th Dec 2020 7:47pm |
