![]() | Home > Maintenance & Mods (L322) > TDV8 Top Intake Hose loose fit |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
serviced mine this weekend i checked all the hoses were fitted snuggly and for any obvious damage i had no oily gunk or any loose fitting hoses. it should be a snug fit to prevent boost leak!
kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1306 ![]() ![]() ![]() |
The end of the hose has a rubber seal in it where it slides over the throttle body. Nobody has found a replacement seal yet so you have to replace the whole hose. I had mine changed under warranty and I think it made initial throttle response a tad better. |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
There is at least one or two threads on this hose on here. Try the Search function |
Sonearly Member Since: 18 Sep 2020 Location: Northants Posts: 218 ![]() ![]() ![]() |
Hi Jayk69
JNC Member Since: 23 Feb 2020 Location: UK Posts: 293 ![]() ![]() ![]() |
You can remove cowling without discharging gas despite what the manual says.
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
I replaced mine because it felt loose. 80 odd quid later and the new one was the same!!
