Home > Technical (L322) > TDV8 used auxiliary heater and now car won't start |
tj196443 Member Since: 08 Oct 2018 Location: Newcastle Posts: 168 |
Sorry to hear about your problem, I'm sure most people may suggest a hard reset of the battery ie disconnecting and then touching the leads. This can happen on Fiat cars where the immobiliser can't get the signal it needs which is usually down to a dodgy earth cable or strap coming from battery. Always worth a check while you wait for more replies. |
29th Nov 2020 3:08pm |
Pikey Member Since: 11 Nov 2020 Location: Cheltenham Posts: 39 |
Battery disconnected and removed from car, and, well, wow - its TINY
29th Nov 2020 3:26pm |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2643 |
Eurocarparts are great for these |
29th Nov 2020 3:49pm |
New battery from Halfords (019 AGM) = car works fine
29th Nov 2020 5:21pm |
