Home > Technical (L322) > Engine doesnt fire - L322 TD6 2003 |
Mads Member Since: 18 Oct 2020 Location: Lommedalen Posts: 16 |
Red off the live values and it seems like LpFP is doing what it sjould. Giving around 4.5-5.0 bar to the HPFP. The HPFP is also givg reading under cranking. So im guessing thats ok. |
27th Nov 2020 6:02am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
It could be that all the glow plugs have given up and need replaced. The engine would probably start even if just one was working. Even though you are getting the preheating message it would be worth also checking the glow plug relay is working correctly.
27th Nov 2020 3:22pm |
Thanks for the tip!
28th Nov 2020 5:24am |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 683 |
If the glow plugs get hot, could be the glowplug relay that's at fault? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
28th Nov 2020 8:19am |
Could, but im getting power to the glowplugs. |
28th Nov 2020 9:00am |
So the glow plugs get hot if connected to 13V directly?
28th Nov 2020 9:28am |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 731 |
Have you tried a squirt of "easy start" or similar?
28th Nov 2020 9:48am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
If you believe you have fuel, and glow plugs OK (but as NDFI says, car should start without them) then next thing to check is the wiring loom to the injectors, and do a leak off test on the injectors to ensure that fuel is actually coming.
28th Nov 2020 12:01pm |
Car is running again; were some cracked wiring to the camshaft sensor that were broke. Had to remive the plug and dig out the soldering iron to get it up and running. Now she starts om the first, wiers it didnt throw any fault. |
28th Nov 2020 9:07pm |
Well done .
28th Nov 2020 10:21pm |
