![]() | Home > Technical (L322) > Engine doesnt fire - L322 TD6 2003 |
Mads Member Since: 18 Oct 2020 Location: Lommedalen Posts: 16 ![]() ![]() ![]() |
Red off the live values and it seems like LpFP is doing what it sjould. Giving around 4.5-5.0 bar to the HPFP. The HPFP is also givg reading under cranking. So im guessing thats ok. |
It could be that all the glow plugs have given up and need replaced. The engine would probably start even if just one was working. Even though you are getting the preheating message it would be worth also checking the glow plug relay is working correctly.
Thanks for the tip!
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
If the glow plugs get hot, could be the glowplug relay that's at fault? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Could, but im getting power to the glowplugs. |
So the glow plugs get hot if connected to 13V directly?
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 752 ![]() ![]() |
Have you tried a squirt of "easy start" or similar?
If you believe you have fuel, and glow plugs OK (but as NDFI says, car should start without them) then next thing to check is the wiring loom to the injectors, and do a leak off test on the injectors to ensure that fuel is actually coming.
Car is running again; were some cracked wiring to the camshaft sensor that were broke. Had to remive the plug and dig out the soldering iron to get it up and running. Now she starts om the first, wiers it didnt throw any fault. |
Well done |
