Home > Maintenance & Mods (L322) > Air suspension and canbus fault
Danwilderspin
Hi all had the abs traction control and air suspension inactive come up.
Plugged Inpa in and it comes up with EHC_2N2 - 50 Can Bus
Any ideas?
Post #425801 31st Jan 2017 9:01pm
Danwilderspin
Date: 01/31/17 20:31:57
ECU: EHC_2N2
JobStatus: OKAY
Variant: EHC_2N2
------RESULT: 1 errors in error memory ! -------
50 CAN Bus
Error frequency : 6
Kilometer counter 244580.00 km
Battery Voltage 14.13 Volt
Reservoir pressure 11.88 Bar
Corner valve front right 0.00 0/1
Corner valve front left 0.00 0/1
Corner valve rear right 0.00 0/1
Corner valve rear left 0.00 0/1
Reservoir-valve 0.00 0/1
Exhaust-valve 0.00 0/1
Compressor-relay 0.00 0/1
Heigh-pressure-exhaust-valve 0.00 0/1
Crosslink-valve rear 0.00 0/1
Crosslink-valve front 0.00 0/1
Compressor-temperature 16.00 Grad Celsius
Vehicle speed 58.00 km/h
average height of car -7.00 mm
general errorr =============================================================
Post #425805 31st Jan 2017 9:15pm
Stacker
United Kingdom 2003 Range Rover HSE Td6 Adriatic Blue
I'm having a similar problem! Have you tried erasing faults from the steering angle sensor and abs modules then doing the steering wheel full lock left to right?
Post #425821 1st Feb 2017 12:20am
alfapat
Scotland 2004 Range Rover Vogue Td6 Bonatti Grey
I guess not by his no reply .
I thought I would pick up this thread by the fact I have a similar fault yesterday with HDC INACTIVE , Air susp. inactive with can bus error 50. I t also coincided with ABS ESP ETC. This had an error with no plausible signal at the time from rear right sensor .
I was on the middle of a long run of 300 mls with no faults whatsoever . Very strange , I stopped in a layby and switched off and started the car again and was back to normal, well only for 30 miles , so after a another 30mls to home I stopped and reset and again everything ok , except that both rear brakes were hot !
The codes that I mentioned were cleared but not been anywhere since . Alot of confusion I guess in the can bus.
What I can do is try the steering turn to turn , .....I will let you know , haha.
Incidentally before the run I changed the inner tie rod , perhaps that is to blame , but I had covered 300 mls after that ? Confused
Much help appreciated.
Cheers Pat
Post #461571 20th Dec 2017 8:52pm
Danwilderspin
Hi sorry moved to another thread as it looks like the steering angle sensor is the culprit - will be changing this weekend hopefully Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #461573 20th Dec 2017 9:17pm
Danwilderspin
Just changed sensor mechanism - cleared faults and we are good
Time taken 90mins following this - it’s very good
https://www.landyzone.co.uk/land-rover/ste...es.312092/ Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #461924 23rd Dec 2017 2:48pm
RRD
Belgium 2012 Range Rover Vogue TDV8 Santorini Black
Bumping this old tread instead of opening a new one.
I bought a 2002 L322 4.4i a few weeks ago knowing it had an air suspension issue.
The car hadn't been driving for a while and the car laid on its belly.
I presumed it was a compressor or strut problem.
Once I got it home I hooked it up to my diagnosis tool and after clearing all faults the car raised and only gave a fault on the left front height sensor. Turned out they had just completely removed the sensor and cut the wires going to the sensor Shocked .
Ordered a new sensor + fixed the cabling and hooked it up to my diagnosis tool again.
On the dash it says 'air suspension inactive' and ABS, yellow ! and ESP ligths are on.
The car fails to calibrate the steering wheel sensor when I turn the steering wheel from full lock to full lock.
Therefore it could be the steering wheel sensor being faulty,
but...
my (and my friend's) diagnosis tool fail to go in the ABS ECU, when we try to read it out it gets a time out and on the air suspension I get the Canbus error code 50.
What do you guys think? ABS electronics? Will try to read the data from the steering wheel angle sensor later to see if the sensor works... '17 Range Rover 5.0 Supercharged AB (Sold)
'16 Range Rover SDv8 AB (Sold)
'15 Range Rover SDv8 Vogue (Sold)
'13 Range Rover SDv8 Vogue (Sold)
'12 Range Rover TDv8 (Sold)
'10 Range Rover 5.0 Supercharged
'03 BMW E39 M5
'01 BMW E46 M3
Post #573011 16th Nov 2020 3:16pm
Danwilderspin
Tough one I can’t remember if I couldn’t read the abs or not but the SAS fault is more and more common i on so probably 5 people in the last year or so who’ve had it where as I didn’t know anyone before I think their age is showing... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #573016 16th Nov 2020 4:12pm
RRD
Found water in the plug of the ABS pump under the bonnet. The plug has already taken one pin of the ABS unit so I'm looking at a new (used) ABS pump and a new plug.
Found this tread regarding plug + wiring: https://www.landyzone.co.uk/land-rover/200...v2.223588/
Will buy a used ABS pump but apparently these need coding? Who's familiar with coding a used ABS pump to the car? '17 Range Rover 5.0 Supercharged AB (Sold)
'03 BMW E39 M5
'01 BMW E46 M3
Post #573224 17th Nov 2020 4:04pm
