Home > In Car Electronics (L322) > No display |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
Did you get any resolve to your issue , I have the same , perhaps it’s too long ago |
14th Nov 2020 4:50pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35406 |
i experienced a 'dim' screen in my TD6 due to a low battery voltage ..i would start by checking that first just to eliminate it. ... - .- -.
14th Nov 2020 5:32pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7953 |
Also check all your connections in the boot - left hand side as you look in - all the electronics are in there & sometimes it's just a poor connection. |
14th Nov 2020 5:40pm |
Yes thanks , I have had a new battery for a few months now, have removed and replaced most of the plugs in the rear , I do think it may be something simple in the end , but it’s finding it lol .
14th Nov 2020 10:36pm |
dennij Member Since: 23 Feb 2019 Location: Up North Posts: 450 |
If the MOST bus is optical, check that you have a red light coming out of the end as it should be a complete circuit. You would need to unplug each optical lead in turn, if you find no light then there is a failure on one of the components or lead. Go back to where you last saw the light and bypass the fault using the biro truck (plenty written about that on the forum) and see if the light now reaches the next connector 2011 TDV8 Vogue SE |
15th Nov 2020 9:30am |
I reckon my system doesn't have optical as I have 2004 model, Thanks . |
15th Nov 2020 10:07am |
markyp Member Since: 04 Feb 2013 Location: essex Posts: 234 |
Hi, I never did find out the problem as soon after the screen went blank The car suffered a
16th Nov 2020 3:16am |
Just had a thought , if the units or unit controlling the monitor on the dash has not shut down properly when I removed the battery negative , would there be a reset button on either the monitor or unit in the boot to reboot the system. |
16th Nov 2020 9:42am |
Also just had a thought, might be nothing though. I remember watching a Wheeler Dealers episode where they had an early L322 that had the same issue as yours, Edd replaced the sat nav unit and all started working again. 2011 TDV8 Vogue SE |
16th Nov 2020 10:25am |
Ok I’ll try and unplug the unit. |
16th Nov 2020 11:30am |
Had a dig around the web for you and others seem to mention the silver entertainment unit in the boot. Corrosion can occur on the blue connector. 2011 TDV8 Vogue SE |
16th Nov 2020 11:49am |
Many thanks , I will check it.
16th Nov 2020 12:29pm |
Would that be the silver unit or DVD player? I’ve just unplugged the DVD unit , still have a backlight in the monitor but still no screen |
16th Nov 2020 12:39pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7823 |
DVD player? Not as standard fit there isn’t. If the sat Nav has been upgraded to the mk4 unit by a previous owner, it will have a DVD logo on the front.... the units can daisy chain, so you should be able to take a unit out the loop....
16th Nov 2020 1:10pm |
