Home > Technical (L322) > FF TDV8 2012 HEATER PROBLEMS
Whyohwhy?
United Kingdom 2013 Range Rover Vogue SE SDV8 Mariana Black
Thanks for the info! I am more concerned with the heater that stops working after 30-45 minutes, I'm hoping the blower resistor may cure this?
Post #572826 14th Nov 2020 10:15pm
clitheroeboy
United Kingdom 2013 Range Rover Autobiography SDV8 Aruba
L405 Passenger air con blowing cold permanently
abs66 wrote:
Did you resolve this issue?
I'm have the same problem, drivers side cold, passenger side warm.
Did you ever fix this issue. same as your problem
Post #608900 11th Oct 2021 11:38pm
Discotigger
Have a look at this topic, this may be your problem.
https://www.fullfatrr.com/forum/topic61127.html
It's the changeover valve that may be the problem, the rubber washer may have rotted / degraded and swollen, stopping the main coolant from reaching the heater matrix after a while. Had the same problem on my FF and this seems to be the solution.
Post #608901 11th Oct 2021 11:54pm
