Home > Technical (L322) > FF TDV8 2012 HEATER PROBLEMS
Fatfred
Hi, i am hoping that someone can throw some light on my heater problems, if my heater on the drivers side is on full temp then it works fine blowing out hot air but as soon as i turn the temp down a fraction the heater blows cold air, passenger side works all ok its just the drivers side, so its either burning hot or freezing cold, can anyone help please, thanks
Post #463960 10th Jan 2018 8:23am
Fatfred
please help, someone must know something FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012
Post #464188 11th Jan 2018 5:37pm
i'm guessing the blend motor maybe....something isnt regulating the hot and cold air.... ... - .- -.
Post #464191 11th Jan 2018 5:44pm
Fatfred
Cheers Stan for your reply, is there a way of testing the blend motor or should i just look at replacing it FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012
Post #464192 11th Jan 2018 5:47pm
abs66
Did you resolve this issue?
I'm have the same problem, drivers side cold, passenger side warm.
Post #536873 10th Dec 2019 7:45am
Fatfred
Hi, still unresolved, have had many people look at it over the last 12 months but all suggesting different things, so i am still looking for a definitive answer FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012
Post #536877 10th Dec 2019 8:26am
umitbat
A Trap 2010 Range Rover HSE TDV8 Atacama Sand
Mine was solved after changing blower resistor.
But it was blowing cold on both sides when not maxed. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #536880 10th Dec 2019 10:09am
Fatfred
Hi, did it blow hot when turned to full heat? FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012
Post #536881 10th Dec 2019 10:39am
umitbat
Yes very hot then cold no fine tuning. 2010 3.6tdv8 180k km.
sold 06 td6 160k
Sold 03 td6 260k
Post #536890 10th Dec 2019 12:40pm
Fatfred
Hi, thanks, that seems like a low cost option to take so will order a new one and give it a go, was it easy to replace? thanks again FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012
Post #536891 10th Dec 2019 12:43pm
j_rov
+1 for the resistor fix.
Mine did this too. __
2018 L405 3.0 TDV6 Vogue SE Fuji White
2000 4.6 V8 HSE Oxford Blue
1994 3.9 V8 Vogue Ardennes Green - resto project
Land Rover History:
2010 3.6 TDV8 Autobiography Stornoway Grey
2001 Discovery 2 TD5 GS
1999 Discovery 2 V8i XS
1994 Discovery 300Tdi
1993 Discovery 200Tdi
1989 Range Rover Vogue SE 3.5EFi
1976 Series 3 2.25
1977 Range Rover 2 door 3.5 Carb
Post #536892 10th Dec 2019 1:18pm
Sadly, RR ownership and definitive answers to problems are unlikely bed mates. Whistle Got - 2017 SDV8 Autobiography in Loire Blue
Post #536911 10th Dec 2019 3:23pm
abs66
Mine is definitely warmer on passenger side and pretty cold on the drivers side so I expect its the valve thingy under the bonnet someone pointed me at.
Having said that, I wonder if it would be prudent to to replace the hedgehog, hopefully it wont be as awkward as it is on an E39! That was not fun!
Cheers for info Thumbs Up
Post #536939 10th Dec 2019 9:17pm
Whyohwhy?
United Kingdom 2013 Range Rover Vogue SE SDV8 Mariana Black
Heater normal until 30 monutes then... Cold
Hi Guy's and Gal's, newbie here, but I guess I'll be a regular!
So my 2013 SDV8 is running pretty fine except.... (how many people say that?) After around 30-45 mnutes, the heater becomes inop or just blows ambient temperature (which is now cold!). That is unless i tyrn the dials up to MAX temp, then she blows hot but only on MAX.
Reading the threads, I see the blower resistor could be a place to start?
Additionally, I sometimes smell burning oil, and once saw slight smoke eminating fromt he front of the grille area whiilst in traffic! The old level is fine (as far as I ca tell), the oild looks fine, no water (white deposits etc.), I don;t see much if any evidence of oil drips, any ideas?
All help or advice greatfully received.
Keep smiling all![/quote]
Post #572689 13th Nov 2020 5:38pm
CS
Heater problems on 322s are often solved by replacing the final stage resistor and lubricating the flap mechanism that directs where the air goes, that cured the two I had.
If the outside temperature is cold enough (5 degrees or lower?) the fuel burning heater comes on. In certain circumstances it will vent smoke to the outside, often from a wheel arch, but maybe depending on wind direction it could also show at the front. If the car is switched off when there is still fuel in the FBH it can burn off for a short while afterwards. That can look a bit alarming if one is not used to it, and it is not that well received by 'green' bystanders.
The 4.4 TDV8 is so efficient that it does not generate a great deal of heat, so one gets the slightly odd effect that there is much better heating into the cabin when it is colder and the FBH comes on than when it is slightly warmer and it does not and one is just getting heat off the engine. Only Range Rovers since 1988
Post #572825 14th Nov 2020 10:10pm
