![]() | Home > Maintenance & Mods (L405) > Service Reveals Action Required |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4319 ![]() ![]() ![]() |
Who do you use out of interest? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 257 ![]() ![]() ![]() |
J Hollick Ltd in Kings Langley.
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 490 ![]() ![]() |
48K is low, that's for sure. |
Seatown Member Since: 30 Oct 2020 Location: Mountains, seaside Posts: 90 ![]() ![]() ![]() |
I'd have thought that the relentless spread of the urban disease of speedbumps (aka traffic "calming") contributes more to premature suspension/wheel/tyre damage than local or country roads. |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
If the car did not come with 22s as stock then they will cause issues with prematurely wear on some of the suspension items. mainly because when they were testing the car the suspension would have been designed around a specific wheel and tyre size. I see this across lots of cars where people put different wheel / tyre combinations on. 2012 Vogue 4.4 TDV8 - Current
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7970 ![]() ![]() ![]() |
22 is a stock size for the L405
Like most parts of the UK, the road surfaces around here vary from poor to really poor |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2665 ![]() ![]() |
As Alistair mentioned, 405 was designed for 22’s. Won’t be the reason. I’d just put it down to bad luck. |
All pre 15my cars are prone to front suspension bush failure... |
Is this due to a modification of the suspension generally or an update of the control arms.
I’m unable to look right now but if you search my old threads, there is a TSB for this (technical service bulletin) on JLR main dealers retro fitting 12,13,14MY cars with 15MY front suspension.
Thanks Craig |
You should see the state of the roads where I live in North Lincolnshire... ![]() ![]() 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
