Home > Maintenance & Mods (L405) > Service Reveals Action Required
SS.Lyria
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Loire Blue
Just had my annual service carried out by my local independent, excellent service as usual Thumbs Up
Unfortunately it revealed that my near side front lower suspension arm bush has split Big Cry
I was surprised because I hadn’t heard anything untoward when going over speed bumps or broken tarmac, often a sign something’s not right.
I’ve owned several D3/4’s and L322’s over the years and with the L405 having covered only 48k it’s the lowest mileage I’ve done where suspension work is required Sad
It’s booked in to be done but can’t help think the 22 inch wheels it’s run on most of it’s life have contributed to the early demise of the bush?
Most of my previous Land Rovers ran on 18’s or 19’s and most of those reached 70k before work was required.
Post #572754 14th Nov 2020 8:59am
DrRob
Who do you use out of interest? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #572771 14th Nov 2020 12:00pm
SS.Lyria
J Hollick Ltd in Kings Langley.
They are a Land Rover independent specialist who I’ve been using a few years now and can’t fault them Thumbs Up
Post #572772 14th Nov 2020 12:23pm
D3Jon
48K is low, that's for sure. Sad
Can't speak re. L405 but you'd think it'd be similar to a L322. With both my L322's, I've replaced the nearside lower arm first, followed usually a year later by the offside. Normally a job done around 70+K as you say.
Are you driving on local / country roads perhaps? Could it therefore be due to road quality, or as you suggest are balljoints and bushes subject to more impact with the lower profile tyres on bigger rims? It would be interesting to see what other forum members have experienced with a) The general suspension wear rates of the L405 and b) Failure mileage of lower arms on FFRR's with bigger rims (21" and up).
With regard to the state of the roads though... please indulge me whilst I get on my soapbox...
<rant> The potholes on the local roads around us seem worse than ever since council budgets were axed. No doubt the bat conservation officer's office will still be fully funded, whilst roads are going to rack and ruin, full of pot-holes with non-existent (faded) road markings, un-cleared surface water drains and encroaching hedges and trees. </rant>
Jon 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Both my fatties now gone...
Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus)
Post #572776 14th Nov 2020 1:23pm
Seatown
Scotland 2013 Range Rover Vogue SE SDV8 Firenze Red
I'd have thought that the relentless spread of the urban disease of speedbumps (aka traffic "calming") contributes more to premature suspension/wheel/tyre damage than local or country roads.
Post #572778 14th Nov 2020 1:35pm
Jayk69
United Kingdom 2012 Range Rover Vogue 4.4 V8 Barolo Black
If the car did not come with 22s as stock then they will cause issues with prematurely wear on some of the suspension items. mainly because when they were testing the car the suspension would have been designed around a specific wheel and tyre size. I see this across lots of cars where people put different wheel / tyre combinations on. 2012 Vogue 4.4 TDV8 - Current
2014 Navara V6 - Gone
2004 Vogue TD6 - Gone
Grand Cherokee - Gone
Discovery V8 (LPG) - Gone
Discovery TD5 - Gone
Post #572780 14th Nov 2020 1:42pm
22 is a stock size for the L405
AFAIK the suspension is the same regardless of whether the car comes with 20, 21 or 22’s
Post #572781 14th Nov 2020 1:50pm
SS.Lyria
Like most parts of the UK, the road surfaces around here vary from poor to really poor Confused
Just luck of the draw I guess. Putting a positive slant on it and assuming I keep the car until it’s covered 100k, they would have needed replacing at some point. So as long as I don’t have to replace them for a 2nd time I guess I’m going to get good use out of the new ones.
Post #572788 14th Nov 2020 2:35pm
Mr Tee
As Alistair mentioned, 405 was designed for 22’s. Won’t be the reason. I’d just put it down to bad luck.
Post #572795 14th Nov 2020 4:08pm
All pre 15my cars are prone to front suspension bush failure... Rolling Eyes
Post #572845 15th Nov 2020 1:12am
SS.Lyria
Is this due to a modification of the suspension generally or an update of the control arms.
If the latter does that mean new one’s will have better longevity?
Post #572859 15th Nov 2020 9:27am
I’m unable to look right now but if you search my old threads, there is a TSB for this (technical service bulletin) on JLR main dealers retro fitting 12,13,14MY cars with 15MY front suspension.
This would be done to rectify issues like yours sir...
Mine was done last year and involves changing front dampers, ARB, ARB actuators, all lower arms and valve block...
Post #572882 15th Nov 2020 1:37pm
SS.Lyria
Thanks Craig Thumbs Up
That doesn’t sound cheap Sad
Post #572895 15th Nov 2020 2:51pm
D3Jon
You should see the state of the roads where I live in North Lincolnshire... Laughing Laughing 1992 RR Classic 3.9 efi Vogue
2014 Disco 4 HSE
Post #572931 15th Nov 2020 5:30pm
