![]() | Home > Maintenance & Mods (L405) > Loose panel - help! |
nwmgc Member Since: 27 Jan 2014 Location: London Posts: 159 ![]() ![]() ![]() |
Answering my own question (so embarrassed to have no responses |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7916 ![]() ![]() ![]() |
I think there is a bolt that goes downwards through the top edge. Might need to undo the side vent to see it. If it’s not a bolt it’s a screw.
Is it the front? Just thinking it might be the rear looking at the pic.... in which case I am no use....
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35671 ![]() ![]() |
you've probably looked in the WM already but in case you havnt the only info i can find is this pic ,
Thank you all - I no longer feel like Nigel no mates! |
JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 911 ![]() ![]() ![]() |
I wonder if a gentle whack will re-locate the clips that hold it on? |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
That looks like the clips have popped out. I had to take a load of trim off when I removed my side steps and had to re-align a load of the clips to get the trim to fit snugly back on. Suggest you prise off with a trim tool and take a look, just check for any screws (maybe in the wheel arch) before prising off. |
AnotherMutley Member Since: 16 Jan 2017 Location: Kent Posts: 400 ![]() ![]() |
Mark
