Home > Maintenance & Mods (L405) > Loose panel - help!
nwmgc
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Loose panel - help!
When washing the FF, I noticed that the panel in front of the osf door, behind the mudflap seem to be poking out. I don't know if this is just a broken clip or whether something more substantial is required. Any thoughts, anyone? Forgive sideways picture!
Post #572282 9th Nov 2020 6:11pm
nwmgc
Answering my own question (so embarrassed to have no responses Embarassed ), it is held in by clips - attached to another plastic mounting plate. I will try and disassemble to see whether something has snapped off.
Post #572570 12th Nov 2020 12:24pm
mjdronfield
I think there is a bolt that goes downwards through the top edge. Might need to undo the side vent to see it. If it’s not a bolt it’s a screw.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #572572 12th Nov 2020 12:34pm
mjdronfield
Is it the front? Just thinking it might be the rear looking at the pic.... in which case I am no use....
..... and it’s not even an L322, I’ll get my coat 🤣 your profile pic threw me.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #572573 12th Nov 2020 12:36pm
you've probably looked in the WM already but in case you havnt the only info i can find is this pic ,
Post #572576 12th Nov 2020 12:52pm
nwmgc
Thank you all - I no longer feel like Nigel no mates!
Post #572577 12th Nov 2020 12:55pm
JCW
United Kingdom 2010 Range Rover Autobiography TDV8 Santorini Black
I wonder if a gentle whack will re-locate the clips that hold it on?
Post #572586 12th Nov 2020 4:30pm
Andy B
That looks like the clips have popped out. I had to take a load of trim off when I removed my side steps and had to re-align a load of the clips to get the trim to fit snugly back on. Suggest you prise off with a trim tool and take a look, just check for any screws (maybe in the wheel arch) before prising off. Thumbs Up SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #572589 12th Nov 2020 4:56pm
AnotherMutley
To be honest, apply a little bit of pressure to the top edge of the panel and centre of the panel and see if that helps.
If not, its not a nice job, to really see whats going on you're into a lot of pain as you've got mudflaps and you'll need to take the wheel off, remove the wheel arch liner, remove the mudflap, swear a lot and finally pop the painted panel off.
There's 2 red fir tree fasteners, a bolt and white nylon rivet that expands (closest to the door edge), my guess is its the white nylon rivet has popped out or the red plastic fitting has broken. The red fittings seem to be sacrificial and the top breaks off them and getting the remains out is a pain. The part number is LEYC000202 36p each. The white rivet you can pull the centre out with a right angled pick.
Hopefully the picture below will help.
Reassembly is the reverse. Big Cry
Cheers
Mark
Post #572678 13th Nov 2020 2:42pm
nwmgc
Mark
Thank you so much - this is so helpful. I got nowhere with the brute force approach and will now follow your eminently cautious and sensible approach. Bow down
Post #573323 18th Nov 2020 4:03pm
