![]() | Home > Off Topic > Car cloned? |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6773 ![]() ![]() ![]() |
A colleague of mine got a penalty ticket for a hire car that he was using but after a lot of messing around, it was established that it was an error in the reading of the registration number and the fact he was 100 miles away from the alleged infraction, sadly the onus was put on him to prove it wasn’t him.
Cheers Alan, the reg. number on their PCN images unmistakably presents as trying to be identical to ours🙄
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1108 ![]() ![]() |
Does your car have an incontrol tracker. letters not necessarily in the right order |
This is a good article on cloning and what victims should expect and can do |
[quote="Dixy"]Does your car have an incontrol tracker.[/quote]
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8003 ![]() ![]() ![]() |
I would imagine a tracker is a good way to prove where your actual car was at any given time. |
Yep letters not necessarily in the right order |
Jayk69 Member Since: 08 Feb 2018 Location: Daventry Posts: 601 ![]() ![]() ![]() |
if you have a android phone you can use you can use maps and the tracking history (If switched on) as well. might not stand on its own but as part of your case. any receipts or card history too will help. 2012 Vogue 4.4 TDV8 - Current
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
Good luck to the OP & anyone else that gets "caught" by the same scam.
Bl4ckD0g Member Since: 16 Feb 2020 Location: 127.0.0.1 Posts: 1322 ![]() ![]() ![]() |
In the U.K. you can only buy your plates from the authorities as well |
Not worried about the PCN or struggling to evidence why it’s not our car on that occasion. That’s incontrovertibly ‘nailed on’ without need to resort to tracker data. It’s the fact that unless or until the offending vehicle is traced and taken out of commission, each time the police/ ANPR are alerted, then our car is liable to be stopped because they won’t know which the genuine vehicle is and which is not... and potential inconveniences like that |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35657 ![]() ![]() |
when traffic wardens are ticketing vehicles wouldnt it be prudent for them to take a pic of the vin number which is visible in most cars...
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Get on DVLA and buy yourself a cheap plate and swap your car to that or see if they will issue you a new one.... So the cloned car is no longer a clone of yours but an flagged as an uninsured and untaxed vehicle and your car is not stopped by the rozzers as the new plate is not on the database.
