Home > Technical (L322) > Lack of power / poor fuel economy? - Possibly fixed |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 895 |
I would be checking your egr valve 1st off looking at that and ur turbo actuator isnt jammed up |
31st Oct 2020 4:38pm |
jim4244 Member Since: 31 May 2012 Location: UK Posts: 853 |
EGR has been blanked Dave. That was one of the first things I did when I bought the car.
31st Oct 2020 5:39pm |
No idea jim mines a v8 petrol but have a look via the search function and look on tube you
31st Oct 2020 5:47pm |
ur20v Member Since: 19 Feb 2019 Location: None Posts: 634 |
Check for boost leaks on hoses etc, performance and fuel economy will go out the window from a small leak. |
1st Nov 2020 9:08am |
Hmmmm.... I can’t see any splits or holes.
1st Nov 2020 1:03pm |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 798 |
Have a look at the Vacuum unit and solonoid hoses for leaks especially at the ends, one goes down to the turbo.
2nd Nov 2020 4:45am |
Wayneg you are a star!
3rd Nov 2020 2:12pm |
Glad to be of help and thanks for the thanks. As you can see on my car the exact same vacuum hose has failed and I changed it to red silicone. If there is enough slack it's easy enough to nip 1/4" of each hose for a tighter seal. 2007 TDV8 VSE
4th Nov 2020 12:16am |
