Home > Technical (L322) > Lack of power / poor fuel economy? - Possibly fixed
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Yesterday I did a 250 mile trip which was mainly motorway and dual carriageway.
I noticed that Sylvia was not as responsive as usual and my fuel economy appeared to be down a little.
Fired up the IID tool and found the below faults
I was going to start by checking and changing the various hoses that can split and degrade. What else should I check?
Jim
Post #571390 31st Oct 2020 2:04pm
Gsxr1250dave
I would be checking your egr valve 1st off looking at that and ur turbo actuator isnt jammed up
Post #571415 31st Oct 2020 5:38pm
jim4244
EGR has been blanked Dave. That was one of the first things I did when I bought the car.
Where is the turbo actuator on a TD6?
Jim
Post #571425 31st Oct 2020 6:39pm
Gsxr1250dave
No idea jim mines a v8 petrol but have a look via the search function and look on tube you
https://images.app.goo.gl/iSzD4ABDzdSKWtaf8
Post #571428 31st Oct 2020 6:47pm
ur20v
A Trap
Check for boost leaks on hoses etc, performance and fuel economy will go out the window from a small leak.
Post #571464 1st Nov 2020 10:08am
jim4244
Hmmmm.... I can’t see any splits or holes.
I was going to replace all the hoses with a set of these
Any other hoses I should check?
Jim
Post #571477 1st Nov 2020 2:03pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Have a look at the Vacuum unit and solonoid hoses for leaks especially at the ends, one goes down to the turbo.
 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #571538 2nd Nov 2020 5:45am
jim4244
Wayneg you are a star!
It has just stopped drizzling so I went out and popped the bonnet and, even though I have been under looking at the inter cooler hoses and prodding around I had completely failed to spot this:
The pipe is in poor condition but I popped it back on and the engine note immediately changed back to its smooth old self. I will take Sylvia for a test drive later and report back.
Thanks Wayneg, fingers crossed 🤞
Jim
Post #571719 3rd Nov 2020 3:12pm
wayneg
Glad to be of help and thanks for the thanks. As you can see on my car the exact same vacuum hose has failed and I changed it to red silicone. If there is enough slack it's easy enough to nip 1/4" of each hose for a tighter seal. 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #571801 4th Nov 2020 1:16am
