![]() | Home > Maintenance & Mods (L322) > Water drops on roof above rear passenger seat? |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 490 ![]() ![]() |
Possible causes could be:
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2218 ![]() ![]() ![]() |
Thanks Jon funnily enough I posted about my rear squirted not working but I’ve not tried it for about a week and this is more recent than that - cannot still leak even if not squirted? Would a drain leak if it is coming out of the correct place by the wheel arch? Current stable:
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
No, but what’s likely happened is the rear/upper tailgate trim has an amount of water in it from the washer pipe or seal leakage and when you open the boot it tips out....
Interesting above the driver rear seat from the door seal edge in about 5 inches the headlining is wet ? Current stable:
Hmm. Could be unrelated to the washer that. sunroof drain? There is nothing that can't be fixed with a hammer😜😜
It comes out in the rear arch as expected could it leak as well of coming there? Guessing it’s a drop the headlining job? Current stable:
Could be something to do with the rear wash wipe..... does it get wetter when you squirt the rear wash??
Lol good idea Current stable:
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 ![]() ![]() ![]() |
You could always drop the head lining on that side, That should give you better idea.
I’m guessing you didn’t have water where I do if that’s where it was though? Current stable:
Great - now the matte on the boot that covers the hatch under the rear fuse box was soaking wet and there were drips on the fuse box... Current stable:
Dan, that must be coming in above the parcel shelf support. Have you taken off the D pillar trim & see if there are any sign of it coming down from there?.
my headlining has one little sag in it as they all go - most wouldn't noticee it but thinking of changing it sooner than planned so I can get it out for a fe days and do some inspecting.... Current stable:
I manged to drop mine by removing the B,C & D pillar trims, Grab handles, to R&R the shark fin. checking the drain tubes.
