Home > Maintenance & Mods (L322) > Water drops on roof above rear passenger seat? |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 418 |
Possible causes could be:
24th Oct 2020 2:09pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
Thanks Jon funnily enough I posted about my rear squirted not working but I’ve not tried it for about a week and this is more recent than that - cannot still leak even if not squirted? Would a drain leak if it is coming out of the correct place by the wheel arch? Current stable:
25th Oct 2020 8:19am |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8501 |
No, but what’s likely happened is the rear/upper tailgate trim has an amount of water in it from the washer pipe or seal leakage and when you open the boot it tips out....
25th Oct 2020 9:19am |
Interesting above the driver rear seat from the door seal edge in about 5 inches the headlining is wet ? Current stable:
25th Oct 2020 1:12pm |
Hmm. Could be unrelated to the washer that. sunroof drain? There is nothing that can't be fixed with a hammer😜😜
25th Oct 2020 1:57pm |
It comes out in the rear arch as expected could it leak as well of coming there? Guessing it’s a drop the headlining job? Current stable:
25th Oct 2020 4:08pm |
Could be something to do with the rear wash wipe..... does it get wetter when you squirt the rear wash??
25th Oct 2020 4:29pm |
Lol good idea Current stable:
25th Oct 2020 5:12pm |
Highroller Member Since: 18 Jul 2016 Location: Hampshire Posts: 565 |
You could always drop the head lining on that side, That should give you better idea.
25th Oct 2020 6:21pm |
I’m guessing you didn’t have water where I do if that’s where it was though? Current stable:
25th Oct 2020 6:47pm |
Great - now the matte on the boot that covers the hatch under the rear fuse box was soaking wet and there were drips on the fuse box... Current stable:
27th Oct 2020 8:11am |
Dan, that must be coming in above the parcel shelf support. Have you taken off the D pillar trim & see if there are any sign of it coming down from there?.
27th Oct 2020 11:27am |
my headlining has one little sag in it as they all go - most wouldn't noticee it but thinking of changing it sooner than planned so I can get it out for a fe days and do some inspecting.... Current stable:
27th Oct 2020 11:34am |
I manged to drop mine by removing the B,C & D pillar trims, Grab handles, to R&R the shark fin. checking the drain tubes.
27th Oct 2020 1:21pm |
