Home > Maintenance & Mods (L322) > About the non-existing gauge in the drain tube TDV8 4.4
AxxA
France 2011 Range Rover Vogue TDV8 Ipanema Sand
Hi all,
Been puzzled by this tiny hose neaby the filler hole for oil in TDV8 4.4 (where the silicon hose is connected).
Asked my mechanics that to me it might be used with a specific workshop gauge.
Specific because of its small diameter that will not allow to use a standard dipstick.
Now comes my question: what about using avec a copper wire as it is rigid enough and small enough in diameter to dip it inside and so, allowing to have both cold or hot oil level?
Starting by a hot level checked using the dashboard reading, then dipping the improvised tool and make a mark, then when engine will be cold, making annother dipping and marking for cold level.
Wasn't able to find any clue for this even checking in BMW M67 or Ford's engine infos.
Any ideas?
Post #570496 21st Oct 2020 12:31pm
mjdronfield
I know there is a tube you can connect a suction pump to, in order to get the oil out from above, but I think that has a long steel tube on it.
Sounds good in theory.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #570497 21st Oct 2020 1:20pm
AxxA
Yes, in theory but... Practically I don't know.
Maybe the most simple thing would be just give it a try.
Post #570498 21st Oct 2020 1:27pm
rjff
The pipe is the suction one for removing the engine oil when servicing. Connect a suction unit with a suitably sized receiver and away you go. There is a drain plug is under the car on the sump and will then only have a small amount remaining when you take it out.
It's no use as a dipstick pipe, that's taken care of by the TFT screen. See the handbook for details of checking the oil level.
PS there should be a cap on the pipe, black, twist and pull off, and not left with a plastic hose attached.
Pic in this thread.
https://www.fullfatrr.com/forum/topic57100.html
HTH.
edit
You can check the oil level with the car cold and the method is on here somewhere. It involves having bonnet open and using the screen to access the menu for oil level.
Post #570500 21st Oct 2020 1:40pm
AxxA
Thanks for your reply rjff, I know about the suction/bolt under the car/dashboard screen.
But, I consider this hot oil/park flat/cut engine/wait 10 minutes (or open the bonnet and press twice on the cancel speed regulator button as waste of time and too complicated compared to a simple metal gauge old style lol.
So, precisely because this hose goes down to the bottom of the sump, why not using it to make an oil check, this was my question.
Post #570503 21st Oct 2020 2:04pm
DrRob
Disco guys have made their own dipstick using this tube. See the sister forum Thumbs Up Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #570504 21st Oct 2020 2:08pm
rjff
Couldn't agree more on checking the oil AxxA, a real PITA.
If your idea of a marked rod works I'm sure it will be appreciated here, so it would be great if you posted up the result Thumbs Up Cheers
Richard
Gap IIDBT
Post #570505 21st Oct 2020 2:10pm
AxxA
Thanks for the clue DrRob, you meant his:
https://www.disco3.co.uk/forum/emergency-d...l+dipstick
(maybe you'll need to be registered to see the topic).
Post #570507 21st Oct 2020 2:20pm
DrRob
Yep Thumbs Up
Don’t follow their measurements though as different engines Whistle Rolling Eyes Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #570531 21st Oct 2020 4:46pm
AxxA
No I won't, but thanks for reminding me.
Will try this WE, first must find something convenient wire or similar.
Post #570532 21st Oct 2020 5:03pm
t5pete
I'm sure some one on here made a gauge out of some wire.
I wonder of a brazing rod would fit down neatly
Post #570538 21st Oct 2020 5:48pm
AxxA
In fact, if if if... if I can have a constant measure:
- mark of the "wire/rod" at the entry of the oil tube when fully inserted (or not, need a diagram of the oil pan to be sure)
- heat the FF, check with dashboard
- plunge the "tester" and mark the hot level (and measure, in case the mark might disapear or be wrong)
- let the FF go completely cold and make a second mark + measure
Redo the process to ensure repeatability.
Then, ideally, make a final dipstick using the black cylindrical cap that closes the oil hose, I mean there is a hole inside it, if the dipstick that I'll marked could fit in, well, this will make a decent DIY permanent dipstick that of course can remain in place all the time.
I am dreaming of a standard dipstick for the TDV8, allowing to make reliable cold oil checks.
Post #570546 21st Oct 2020 6:10pm
Discotigger
Is there a way to get the Oil Level on the TFT when the engine is warm / up to temperature. I only get the Oil Level when the engine is cold, won't show a level on the service menu once you have started the car and run the engine.
Noted in a post above something about opening the bonnet and pressing buttons on the wheel. What do you do exactly and will this be the same for a MY12 Model 4.4 TDV8?
Cheers for any pointers! Bow down Bow down Thumbs Up
Post #570547 21st Oct 2020 6:15pm
Baltic Blue
https://www.fullfatrr.com/forum/post569349...031#569349
Check out this post.... for the L405, but very similar.
Post #570549 21st Oct 2020 6:17pm
DrRob
So, read when cold or
Read 20min after shut down of a hot engine.
Simples.
You can over ride Unavailable messages any time with bonnet open and press cruise cancel twice when the message pops up saying unavailable but readings won’t be as accurate naturally.
That’s it. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #570550 21st Oct 2020 6:23pm
