Home > Technical (L322) > Engine system fault |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 491 |
Hi could well be the cracked inlet manifold which is pretty common. Have a search on here and there are quite a few posts on it.
20th Oct 2020 6:42am |
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 141 |
Hi I haven’t checked the lower hoses yet so I’ll give them a go next. I’ve heard they can be a nightmare to fix but not sure tho? I’ll have a look at the manifold but this is gonna sound weird but they look newish but I’ll check the with the soapy water and see what happens. Really weird tho as driving for all those miles and it was perfect then boom that happened. Bloody pain |
22nd Oct 2020 12:38pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3144 |
William spend a little bit of mooney and get a HIGH pressure smoke test done. My pax inlet manifold had hairline crack which didn't show up until I got a HP smoke test done. Cost £1600 for new manifold (involves a new injector harness or stg!) |
22nd Oct 2020 2:01pm |
My inlet manifold looked brand new when it needed replacing and I couldn't see the split and as you have done it would drive for miles then let go. Found the leak with some soapy water sprayed on. May be easier if you have someone rev it too while you spray it on.
22nd Oct 2020 8:30pm |
Hi guys I’ve booked in for a pressure test but he can’t do the smoke test. Does anyone know who can do a smoke test in the Essex area?
25th Oct 2020 5:02pm |
I'm not sure a pleasure test will do much good as you know there is a boost leak somewhere already so you need smoke to come out to pinpoint where is from.
25th Oct 2020 7:38pm |
