Home > Maintenance & Mods (L322) > LED Hi-Beams - With Pics |
So, in comparison they look fantastic. Looking at the photos though it seems the halogen is still quite a lot brighter ???
27th Mar 2011 8:50am |
Wiggins Member Since: 27 Feb 2011 Location: Glasgow, Scotland Posts: 94 |
just ordered the 120, great find! |
27th Mar 2011 1:42pm |
AMD Member Since: 16 Jul 2010 Location: The South Posts: 811 |
Thanks Dan, all ordered Current MY2020
27th Mar 2011 5:26pm |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 |
I might order some when a new release of Navcoder can actually talk to the LCM and turn the DRL's off.
27th Mar 2011 6:00pm |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
I thought Nav coder already did.. turns them on and off on my '03 with the option of sides, heads(flash) at certain percentage of brightness for that "moody" look 2010 Disco XS TDV6, 2009 Freelander 2 GS
27th Mar 2011 6:57pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
my navcoder can talk to and programme the LCM V8 facelift Range Rover Autobiography 22" wheels.
27th Mar 2011 6:58pm |
Ahh, sorry, I should explain, the original version of Navcoder I had coded the LCM fine, then, after a few months, there were several updates, last time I tried to connect to the LCM to turn off the DRL's, I clicked read, then the DRL option was unavailable so I couldn't turn them back off. I think there's been an update since so I'll try turning them off again. 2006 Mercedes CLS
27th Mar 2011 11:20pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
the bigger ones wont fit through the main beam hole DAN, only the 18's fit....i have 18's in my 'main beam' and use them as drls [with switch] and i have put the bigger 68's in my fogs [use as mains].. ... - .- -.
28th Mar 2011 7:34am |
Odd - my 18's were originally for my fogs but they wouldnt fit through the hole! Yet they fit fine in the main beam? |
28th Mar 2011 7:36am |
my 18's fit the fogs and obviously the mains but the bigger smd's dont fit the mains cos the cluster diameter is to big...
28th Mar 2011 7:38am |
hi, here is a video of my 2006 test lamp with the 68 led bulb 5500k fitted,
28th Mar 2011 7:24pm |
That's pretty damn bright! 2006 Mercedes CLS
28th Mar 2011 8:03pm |
More pics:
28th Mar 2011 9:21pm |
hi, in all fairness you dont get as much light projection as with the halogen but as i drive in london most of the time its not a prob i get plenty of light from the bi xenons, what i do like is the fast response they give,instant on and off, may be the 120's will give more projection.. V8 facelift Range Rover Autobiography 22" wheels.
28th Mar 2011 9:29pm |
