Home > Maintenance & Mods (L322) > LED Hi-Beams - With Pics
Page 3 of 4 <1234>
dan_uk_1984
daveo wrote:
hi, in all fairness you dont get as much light projection as with the halogen but as i drive in london most of the time its not a prob i get plenty of light from the bi xenons, what i do like is the fast response they give,instant on and off, may be the 120's will give more projection..
As you say with the Xenons, especially Bi-Xenons really the Halogens are only of use for flashing other drivers...
Post #57236 28th Mar 2011 10:38pm
daveo
here you go, i have fitted the 68 led version of the H11 5500k LED bulb in the front fogs, firstley it gives you the xenon white light to match the side lights, they are ok as driving lights but you will need to run around with your lights on,
you will get the fog light warning message come up but this can be switched of with navcoder and then you will not get any warnings, very easy to fit apart from one thing, when you pull of the fog light ring of the clips ping of in side and could not be found, so i do hope they can be bought seperately as i need several.
standard bulb
68 led bulb
 V8 facelift Range Rover Autobiography 22" wheels.
Post #57412 29th Mar 2011 9:21pm
leds/smds are defo the way to go.. Thumbs Up ... - .- -.
Post #57413 29th Mar 2011 9:23pm
daveo
i went for the 68 led bulb and thats rated at 3 watt, the 102 led bulb is rated at 6.5 watt so would be twice as bright
http://cgi.ebay.co.uk/2X-H11-102-SMD-3528-...3682wt_947
the only downfall of the led's are they dont project as much light as the standard halogen but i fill they look far better as with the high beam led. V8 facelift Range Rover Autobiography 22" wheels.
Post #57451 29th Mar 2011 10:50pm
AMV
2011 Range Rover Vogue TDV8 Santorini Black
Guys, can we put these LEDs on 2010+? Is it possible to disable the check lights warning for fog lights on recents RRs? Santorini Black RR Vogue 4.4 TDV8
Post #58364 2nd Apr 2011 10:04pm
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Guys,
haven´t upgraded my front so will the 120s work in the old headlights 02-05 or in the fog lights ?
Can I change a possible failure warning with the testbook T4 or do I need explicid the navcoder?
They´re cheap and it take some days until the bulbs will arrive, so I ordered 2 sets. If they will not fit in the RR, maybe they will work in our Audi. Whistle XJC, RRV8, Series1 86 and 107% of real pleasure
Post #58391 3rd Apr 2011 9:44am
dan_uk_1984
They are still H7 bulbs regardless of housing so think you'll be OK Thumbs Up
You should get Navcoder anyway - it's very useful!
D
Post #58403 3rd Apr 2011 11:03am
AMD
I have fitted the 68 LED's in the headlight units plus the LED sidelights bulbs and they work a treat. It wasn't until I started the engine whilst the car was looking into a shop window (admiring itself) that I noticed that the bulbs 'blinked' on start up (testing) which to me is an added bonus. All day I have been a Christian driver, flashing cars out from side roads etc.
They bring a smile to me anyway Very Happy Current MY2020
Gone: 1 x L405 and 2 x L322's
Post #58558 3rd Apr 2011 7:22pm
dan_uk_1984
Get some pics up of those 68 LED's!
Post #58565 3rd Apr 2011 7:51pm
Just arrived from HK
120 LED's in main beam ( no fault code protection )
Side lights 8 LED's ( with fault code protection )
5,500 k
No errors showing on dash.
 2008 MY Supercharged
Post #59039 6th Apr 2011 2:17pm
I'm liking that look! Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #59043 6th Apr 2011 2:20pm
daveo
axle, put up a link from ebay so others can order the same as you have... V8 facelift Range Rover Autobiography 22" wheels.
Post #59179 6th Apr 2011 11:00pm
dan_uk_1984
My 120 Hi-Beams have arrived. Whoop Whoop!
07042011311 by d86cfv, on Flickr
07042011312 by d86cfv, on Flickr
Post #59242 7th Apr 2011 12:13pm
GregP
United Kingdom 2002 Range Rover HSE Td6 Adriatic Blue
Just fitted some new LED side lights.
http://www.car-mod-shop.co.uk/Land%20Rover...ight_bulbs
Heres a pic
certainly an improvement on the old dull lights. FFRR TD6 HSE
Adriatic Blue with Parchment leather.
Post #59333 7th Apr 2011 9:36pm
daveo
I Hope you never paid 15 Quid for them Shocked V8 facelift Range Rover Autobiography 22" wheels.
Post #59587 9th Apr 2011 8:06pm
Page 3 of 4 <1234>
