Home > Technical (L322) > Hybrid TV Unit 2011 Vogue SE/No audio
66jag
Just looking for some advice please, my Hybrid TV unit failed and having checked the price with LR, (£1300 + VAT....😱) opted for a second hand unit identical to mine, my question is, should this be plug and play or will it need to be configured? The touchscreen is now working fine with no greyed out buttons but I can’t select anything other than analogue radio and there’s no sound at all. Before anyone asks, I’ve plugged the car into SDD and there are no codes....advice gratefully received. TIA
Post #569892 15th Oct 2020 3:36pm
dennij
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Buckingham Blue
I'm not 100% sure but I believe they have to be programmed to your vehicle as they are VIN locked? 2011 TDV8 Vogue SE
Post #569894 15th Oct 2020 3:57pm
66jag
Thanks, I was lead to believe they were a like for like replacement providing you kept to the same model serial number, as you say that may not be the case given the one now fitted has no audio/DAB/TV output.I was careful to find a unit very close in production number to mine to avoid any compatibility issues but unless there's another issue I'm not aware of perhaps it needs programming. Before I fire the parts/diagnostic cannon I think I'll try a hard reset....
Post #569895 15th Oct 2020 4:08pm
do a battery reset to see if it reboots the ecus.. ... - .- -.
Post #569897 15th Oct 2020 4:37pm
66jag
Thanks Stan, was just doing the hard reset before I saw your post which has done the trick, all working fine now.
Post #569905 15th Oct 2020 5:25pm
Thumbs Up ... - .- -.
Post #569907 15th Oct 2020 5:31pm
