Home > Technical (L405) > Looks like something is missing
BuddySpire
Still keep having a bit of coolant leak its either very slow or a sudden leak of around a litre then stops again. Engine is 4.4 2015.
It's had the oil cooler gasket changed twice and then the oil cooler unit changed by MD. Decided today to have a look to see if I could see where a leak was coming from with my inspection camera.
Couldn't see any evidence of a leak on top of engine but did find what looked like a hole for a sensor or the like with what looked like marks showing something was fitted once.
the hole is to the left side of the oil filter at say 11 o'clock when looking at the engine from the front.
close up
showing location
Any ideas looked at oil cooler pictures but can't see anything that resembles this.
Thanks
Post #569693 13th Oct 2020 12:27pm
BuddySpire
Looks like a possible pipe bracket that’s missing. Not 100% sure but looks like it.
Post #569700 13th Oct 2020 1:54pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
My 2016 4.4 also had a very similiar coolant leak- never any sign of any leak under the car but it would lose a litre every 500-700 miles.
Took ages for Landrover to find it having changed various components including the Oil cooler - there was never any sign of any leak under the car. It was eventually traced to the EGR cooler. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #569704 13th Oct 2020 2:19pm
How long has it been since the gaskets were changed etc. It could be that what you are seeing is airlocks working their way out of the system. Keep topping it up and see if it stabilises over a few weeks. There is nothing that can't be fixed with a hammer😜😜
Post #569729 13th Oct 2020 5:58pm
BuddySpire
I had the airlocks about a week after the last time it was in. This time low coolant warning came on weeks after it was in garage end of July. Always seems to be a few months after they sort it it starts again.
Post #569745 13th Oct 2020 7:13pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Hi , not the same symptoms bit my 4.4 2015 L405 has a very slow leak over the last 6.momths and was finally traced to the thermostat housing.
This is the underside 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #569751 13th Oct 2020 7:49pm
BuddySpire
I saw that on an earlier post will investigate to see if any signs of leak.
Post #569753 13th Oct 2020 7:53pm
dolph34
As I say , different symptoms but worth checking Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #569755 13th Oct 2020 8:04pm
