Home > Maintenance & Mods (L405) > Adaptive Cruise Retrofit to 2014 L405 Vogue
Mark1107
United States 2013 Range Rover HSE 5.0 V8 Fuji White
Ans
Patrick Meilleur of GAP can walk you thru to fix it. Retrofitting it requires an ECU flash that gap charges 35 bucks for and it enables our car to accept the changes.
You need the ACC module camera the LDW switch button on lower dash and the correct rear view mirror. Plus the gap tool.
Post #565106 21st Aug 2020 7:18am
pherplexed
United States
Mark1107 - Ans has already completed the installation and just has some questions about a few of the values on the CCF configuration.
Ans – I have not had a chance to reconnect my IIDtool to see if those extra two values have been configured on my spec. I will try and take a look this afternoon.
Are you still getting the park break and cruise control errors? If so, have you tried clearing the faults with the IIDtool to see if that clears it up? 2021 P525 | Eiger Gray
Post #565122 21st Aug 2020 12:55pm
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
I have a 2013 L405 with ACC fitted and high beam assist etc. can I retro fit lane assist, and does it gently nudge you back into the lane with it being electric power steering?
Also if IID unlock the ECU do I then have more options than I do currently in the CCF? Reason I ask, is that My L322 has a huge list of options in the CCF already, where as the L405 has a limited number of options in the CCF?
Post #569677 13th Oct 2020 9:12am
Charles, you need to ask Pat at GAP for an un-tested version of the firmware .. ... - .- -.
Post #569681 13th Oct 2020 9:23am
Charles89
Brilliant. and I do that how...? Email or do they have a contact number..
Post #569683 13th Oct 2020 9:30am
PMeilleur@gap-diagnostic.com
Thumbs Up ... - .- -.
Post #569685 13th Oct 2020 9:38am
Charles89
Thank You Stan! I Have emailed him Thumbs Up
Post #569686 13th Oct 2020 9:47am
sconnell80
United States 2016 Range Rover 5.0 SC V8 Corris Grey
Was super excited to find this thread and got the parts needed to do the retro on my 2016 l405, got the parts all around and installed the radar sensor only to find that I have no wiring for it located on the bumper. Complete bummed, so I guess the next question is would I be able to buy the wire harness that would let me finish this retrofit seeings how I have all the parts?
Post #679207 1st Dec 2023 10:40am
